Question about Panasonic Office Equipment & Supplies
I have a Panasonic KX-MB1900 All-in-one Printer. I want to print using the "Input Tray #1" but when I start to print, an error message pops up: "Out of Paper Tray #2." How will I change the set-up to make the machine print using the Tray #1 as a paper source? Thanks!
Mrvica
  • 167 Answers
SOURCE: Selecting a default paper source for a specific program
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Posted on Jan 30, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
Posted on Jun 06, 2008
  • 13 Answers
SOURCE: IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Posted on May 19, 2009
n25an
  • 622 Answers
SOURCE: When trying to print, get error message to load
if all the other trays are empty
or the bypass is set as default
or the bypass has the correct tray size and no one else has it
then the bypass will be default...
Posted on Dec 09, 2009
  • 9 Answers
SOURCE: HP P3005N printing from Tray 1 and not Tray 2.
Do a cold reset and the paper trays will reset themselves, it's the easiest way. Turn printer off, turn the printer back on and as soon as you see the memory starting to count push the check mark button and HOLD IT until you see all the lights stay on. When they stay on, and you see "select language", push the arrow button until you see "cold reset", and push the check mark button again. You will be all set.
Posted on Jan 20, 2010
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
UNABLE TO PRINT FROM TRAY 1 PANASONIC
Try this:
Open a document to print
Open print preview and select properties/printer properties
Look for Paper/Quality, then Source
Choose Tray 1
Mar 22, 2013 | Panasonic KX-MB1500 A4 Mono Laser...
Change drum error in panasonic kx-mb1900
Dear friend , you guided about Brother printers not for Panasonic . There is no any option key on the panel of Panasonic kxmb1900 .
Dec 14, 2012 | Brother IntelliFAX 3800 Plain Paper Laser...
Panasonic kx-mb1900 call service 3
try this
Press Menu
#9000
* 550
Press SET
Poweff Off the Printer for 30 Seconds
Power on the Device...
Enjoy!!!
Jul 23, 2012 | Panasonic KX-FL511 Plain Paper Laser Fax
How can resolve call service 3 problem in panasonic kx mb 1900 printer
i have one panasonic KX-MB1900 all in one printer problum showing call service 3
Apr 22, 2012 | Panasonic KX Office Equipment & Supplies
Check rear cover msg display on my printer kx-mb1900
I have a problem with my panasonic printer when i have start my printer msg display check rear cover...plz help me.
Jan 19, 2012 | Panasonic Office Equipment & Supplies
Call service 3 panasonic kx-fl612
hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
Jun 24, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
119 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
