I have problem in my washex machine ( power supply ) my tec change other washex power supply unit than error show reset how can i fix this problem
My company tec change other machine one by one some part but still its same what to do advise me
5 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: Ricoh Aficio CL3500N error code SC581
Q1 - Possibly, I have not seen an SC581 error before. Usually using too much power would give you something like an SC240 error "Power Supply Excessive". So it depends on the extent of the damage. You could also have to replace the main board, motors, etc.
Q2 - You will have to pull back the feeder tray, remove the back panel, there is a cover over the main board and the power supply is below it and fairly easy to get to. But if other components were damaged it could be a much more involved repair.
Posted on Jul 24, 2008
odiegh
  • 81 Answers
SOURCE: Canon Gp200 Error Code E000-001
I looked up the e000 and it said it's for the fuser using not heating up and 001 error code and it is that the fuser unit is overheating. So seem to me you have a bad fuser unit.
Posted on Jan 02, 2009
  • 217 Answers
SOURCE: changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
Posted on Apr 05, 2010
Cogz
  • 1326 Answers
SOURCE: i install new imaging unit cyan and magenta but
Did you turn the main power switch OFF then back ON? You need to do that to reset the counter. Also, did you put a brand new one in from a closed box or a used one? If it is a new one & it will not clear, return it to where you got it from... Good Luck
Posted on May 23, 2010
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
How to fix samsung washing machine model TORNADO 7.0kg WA90B error
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Nov 01, 2012 | Washing Machines
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
-Display Shows 'E1'
Keep me posted!
How to clear error code E000051-0000 in canon IR3300 copier
To reset the error
1. additional functions (push)
2. function (choice)
3. error (choice)
4. error code choice (wait)
5. reset (push)
6. right power supply off
7. right power supply on
Apr 16, 2012 | Canon Office Equipment & Supplies
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
this error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Jul 22, 2009 | Canon imageRUNNER 5000 Copier
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
24 people viewed this question
jasbo
jasbo
