Question about LG 50PC5DC 50 in. Plasma HDTV
I have a 50" LG plasma that turns off after a couple of minutes.
The tv turns on and then shuts off after a minute or so. I can turn it back on but it keeps shutting off. I did take the back off and look at all the capacitors and none are blow on top.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Check the solder side of the pc board. If there are any connections that look grey (as opposed to shiny) you need to re-solder them.
Posted on Dec 12, 2014
3 Suggested Answers
hbsurfdawg
  • 95 Answers
SOURCE: 50" lg plasma tv keeps shutting off
Your Television uses a sensing circuit that is basically part of a mini-computer. Sometimes either the sensing unit can be bad itself or there is a power distribution issue.
Test - Make sure you try another input source like DVD or something other than what you are trying now. If it plays and does not shut off, the TV might be ok, it might be something to do with your other source you were using when it went out, like your cable box etc.
(most LG's have input sensing and if there is nothing coming in the TV it will shut down or go into standby)
If you have run this test my friend, you may have no choice but to take it in or have a service call. A LG specialist might bring the board you need in to repair it but that can be rare. Most of the service guys that come out are following instructions in a systematic troubleshooting guide and do not really know how to troubleshoot per say, they are card replacers until it works.
They cannot fix the problem in the home if you cannot repeat the problem in front of them and it is consistent.
You may want to call LG or Write their tech dept (good luck, they kind of are not that customer service oriented that I have seen).
I always recommend the extended warranty on a high-ticket item next time.
Hope that hepls and let me know how it goes.
E
Posted on Mar 02, 2009
toolkits
  • 1099 Answers
SOURCE: My LG 42"tv shuts off by it self
hello, The best way to fix this is by opening the back cover of the television set.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Posted on May 20, 2010
50 inches LG PLASMA TV TURNS OFF AFTER 15 MIN.
A blown capacitor might not be the reason. After 15 to 20 minutes of work, the temperature inside the set do rises much, this kind of fault can occur. Check its cooling fans.
Jun 25, 2013 | LG 50PT350 50 in. Plasma TV
Just bought an LG Plasma Screen TV. 50' 50PV400 I turned it on, and the picture was there. After a couple minutes the picture is no longer available and the screen turns black while the sound...
The tv is faulty and the fact that it failed immediately after you have started it for the first time is a clear indication of a manufacturing defect.
Take the tv back to the seller and ask for a replacement one or your money back.
Jun 01, 2011 | LG Televison & Video
LG 42" Plasma - remote wouldn't turn off TV, nor
unplug for a couple of hours. the tv holds charge and bleeds off electricity very slowly.
Mar 22, 2011 | LG 42PG20 42 in. Plasma HDTV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV shutting down automatically after a minute
I also have this TV but mine will not power on at all. Did you ever find a solution?
Max.
Jun 25, 2009 | LG MU-60PZ10 60 in. Plasma Television
LG 50" plasma will turn on then shut off shortly there after.
Unplug the power from the power outlet and let it sit for a few minutes. Then plug it back and it should work normally.
Apr 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PC5DC 50 in. Plasma HDTV Logo
150 people viewed this question
Computer Repairing
Computer Repairing
