Question about Saws
How do I remove the bearing from the drive end of the armature from an AEG WSE802 Angle Grinder?
Have the armature out and the non drive end bearing removed.
    Sergeant:
  • 213 Answers
Dear Michael,
Here offered is a video by Taimo T that offers the entire process. Close attention is needed to absorb his procedure. The foundation is the basis for angle electric grinders.
Angle Grinder And Its Bearings
Please watch the entire presentation.
A small bearing puller works best. Here is examples of one to buy or borrow.
A
ATD Tools 3056 Bar Type Puller Bearing Separator Set in Molded Storage and....
B
Pump Pulley Remover Straight Type Two Claws Bearing Puller
Hand Tool
C
Wilmar W137P 6 3 Jaw Gear Puller
D
Neiko 19 Piece Automotive Bushing Bearing Driver Tool Set
The alternative is to squeeze the old bearing in a vice with soft jaws . Then move the end shaft with a brass hammer or punch to remove with an internal fit.
Fare. Well.
Posted on Dec 13, 2014
SOURCE: something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Posted on Mar 08, 2009
housejess
  • 317 Answers
SOURCE: angle grinder
on a grinder the nut that holds the wheel on has left handed threads.....that means it has to be turned in the opposite direction than conventional nuts do..there should be a button on the casing to hold in..this keeps the grinding wheel from turning wheel being removed....remember to unplug first..thanks and have a great day
Posted on Jan 03, 2010
  • 39 Answers
SOURCE: replacing the gear on makita angle grinder
Are you replacing both gears? The armature gear (pinion) is usually held on with a nut or else is pressed on. The spindle gear is also pressed on. Most spindle gears will come as an assembly with the gear and spindle and housing all together.
If yours doesn't, then the spindle will need to be pressed out of the housing, and then the gear pressed off of the spindle. (Always replace the grease as well when replacing gears.)
Posted on Apr 24, 2012
  • 47 Answers
SOURCE: Remove armature from grinder housing
If you have a shot armature then it will spark a lot where the brushes are touching the armature comulator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good .
If my information helped you plz give me markings. Thanks
Posted on May 17, 2012
tiberiann
SOURCE: armature problems
http://www.toolsandmachinery.com/blog2/tag/repair-9564cv-grinder/
Posted on Jan 12, 2013
The bearing on the armature of my Bosch 4000 table saw fell apart and now only the inner part of the bearing is on the armature. How can we remove this?
you will need a knife edge bearing puller available from an auto parts shop or a good tool shop
it will be a small puller that comes in to sections which are bolted together under the inner race of the bearing ( bit still in the shaft) and that section is attached to a bar with a screw through it that then pull the inner race off the shaft
or if you are very careful , you can use a 4" angle grinder with a 1mm cutting blade and cut across the bit at an angle NOT IN LINE WITH THE SHAFT -as that will give the blade clearance to the windings -- so that the blade is clear of the windings
cut down about 1/2 way then using a steel solid support under the bearing race , place a sharp cold chisel in the cut and using a ball pein hammer hit the chisel into the cut
that will crack the rest of the race and you can then get it off with your fingers
NOTE---IF YOU USE THE GRINDER AND YOU TOUCH THE WIRES WITH THE BLADE IT IS A NEW ARMATURE AS WELL AS BEARINGS SO BE VERY CAREFUL WITH THIS METHOD
Feb 19, 2017 | Bosch Saws
How do I replace gears milwaukee 6123-31 angle grinder?
Dear Ion,
Here is a video worth viewing. Angle Grinder And Its Bearings .
This site offers almost all you need. I offered the link to show and tell how to get there. Research your device onward.
Milwaukee 6148 30 SER B71A 4 5 Angle Grinder Parts
To remove the gears, it is helpful to borrow or purchase bearing pullers. Here are on examples.
A Neiko 19 Piece Automotive Bushing Bearing Driver Tool Set
B Amico 75mm Length Center Bolt Two Jaws Bearing Gear Puller
C Wilmar W137P 6 3 Jaw Gear Puller
D ATD Tools 3056 Bar Type Puller Bearing Separator Set in Molded Storage and...
If you have a vice, soft jaws , are placed on an outside bearing racing fit to be held. A Brass hammer or drift pin may be used to strike the armature without damage to move the bearing for clearance. Another person may be needed to catch the shaft from falling. In the case of a internal bearing care must be observed,however, Sockets that fit in the area make great devices to drift the bearing should there be room to employ the repair process.
Fare. Well.
Dec 08, 2014 | Electric Eyeware Milwaukee 5" / 6" Angle...
Could you please help me repair my Makita angle grinder?
The problem will be removing the inner bearing ring from the armature. You will need to source a suitable bearing puller from a hire shop or possibly get one made.
It will look like a tube with a slot in the side.
The bottom will have a plate welded on it, also with a slot.
The slots allow the puller to pass over the armature enabling the puller to centralise over the shaft,
The top of the puller will have a plate welded on with a hole through the centre. On this plate is welded a nut.
A bolt will pass through the nut and contact the armature shaft.
with the puller centrally located over the armature and the bottom plate in contact with the bearing the bolt is tightened to pull the bearing up.
I have made a puller similar to this from an old spark plug socket (good quality from as socket set) but it may not be long enough for your application.
Aug 31, 2017 | Saws
My Makita "GA9020 9"" Angle Grinder has started to vibrate really bad.there seems to be play in the spindal.its used for floor sanding.i was thinking maybe bottom bearing,but just guessing any ideas thanks
Vibrations and excessive play could be caused by one of two or both bearings in the gear housing or the spiral bevel gears. Armature bearings can cause vibrations but usually don't show up as play at the spindle. Also, if the vibration is really bad, you could have several fan blades broke off one side of the armature fan throwing off the balance.
Oct 09, 2013 | Makita "GA9020 9"" Angle Grinder- 15 AMP-...
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 | Saws
Replacing the gear on makita angle grinder
Mar 31, 2012 | Makita Saws
I am about to pull out the armature and there is a shield under the cooling fan (which is conected to the armature) that should slide out with the armature. It is real tight and I do not want to pry to...
Yes it should pull out with the armature. The plate can only be removed after you remove the nut and gear on the end of the armature. Make sure your brushes are pulled out first or they can hang up on the bearing at the other end of the armature which may be what is happening in your case.
Jul 11, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
How do you remove the crown gear?
The gear on the end of the armature is held on by a metric nut. The armature shaft is threaded. The larger gear is press fit onto the shaft. You need a hydrolic press to remove it.
Jul 08, 2011 | Bosch 7" Large Angle Grinder 1873 - 8
How to replace main bearing in a Makita GA5000 5'' angle grinder. I removed the clip in the gear head but can't remove the gear to pull the armature. The main armature bearing in the gear head is shot.
i used to grab the armature and tap the housing off with a rubber hammer...
try tapping in opposite corners every time....
when it does fall have a cushion ready on the bench or floor to catch it...
Jul 10, 2009 | Makita GA7020 Angle Grinder
Something wrong with the armature
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Saws Logo
207 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
