Question about Video Game Consoles & Games
Update stopped. can't read the update from my storage device. Status code 41Ff-42FC-2780-0F00-C000-0034
I think I need to formate my memory stick to my Xbox 360, so I can get this update and play Madden again. I don't know how. Also, I wanna get longer instant replays when I play Madden 15
SOURCE: I get status code: 69-C00D36C4
right click the folder and make sure the folder is shared and permisions are set to FULL read and write.
Posted on Oct 06, 2010
walesarumi
  • 6993 Answers
SOURCE: i was updateing my xbox360 and now all it dose is
Update failure When the xbox360 tells you an update is needed, but the update will not complete properly. There are some reasons that can cause this to happen.
1. There are some corrupt files on your hard drive or your hard drive does not have enough space left.
2. There are some previous downloads stuck in your download queue.
3. There are some settings in your router that are blocking the download.
You will have to reset your Xbox360 to resolve this issue.
Let me know is you don't know how to reset your Xbox360 so that direct you on how to do it.
Good luck.
Posted on Feb 24, 2011
insanical
  • 5 Answers
SOURCE: I put a game in
Make sure the disk is clean.
Reinsert and try again.
If it does not try to update again and it tries play the game but does not work and it is not because it cannot read the disk then go to the settings, hard drive and go to "System Cache" and delete.
This will delete all temporary files. Which means all small updates for games will be deleted. I reccomend doing this as it may be an error due to the update being stopped halfway through therefore being unfinished. So the xbox may recognise that the update has been installed but because it is unfinished then it may not be able to start the game.
If this still does not work try disconnecting from the internet as it will not ask for an update and you will be able to play the game without it. If this does not work and the game does not play it may be a problem with the disk.
First I would suggest playing the disk in a friend's xbox. If it still doesn't work, take the disk back to the shop and get it replaced.
Posted on Mar 02, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: xbox 360 update error is this: status code: 22FB -
Hello
There are two ways around this.Both you will need a pc.
Log into x box live and find system updates.Download and save to my documents or desktop,somewhere you can find them easy.
1 use a usb flash drive to download too.Then upload it into the x box.
2 Or burn the update to a cd or dvd and run it on the x box .
Posted on Sep 27, 2011
SOURCE: unable to read update from xbox 360 hard
Hi, i have the same exact error, did you aver fix it, if so, can you please tell me how.
thank you
www.playstation3xbox360repair.com
Posted on Nov 19, 2011
My memory stick is showing write protected, how do i remove it, does not even wamt to format
hi thembi.
Go to My Computer and under Devices with Removable Storage look for your cardreader; right-click on it and click Properties. In the pop-up box, sometimes there's an option to Remove write-protection. Change the status of this option and try again. Remove your memory stick from the drive.
How to Format A Write-protected SD Card/USB Drive/Pen Drive ...
or go to this link and have a read up.
memory stick is showing write protected Google Search
Nov 17, 2017 | Electronics - Others
Xbox 360 status code 4174-42FC-A080-0C00-8007-2741 Help how do I fix this? I can't get my xbox to connect to live.
The second section of your error code is: 42FC (in hexadecimal). Convert 42FC to decimal = 17148. Search Google or Youtube for fixes to the XBOX 17148 error. There are suggestions on how and why it happened.
Dec 06, 2014 | Video Game Consoles & Games
Its telling me the hard disc is corrupt and is reloading it but it doesn't fix it and takes ages but is the same
Your hard drive has a problem and needs to be formatted. this has happened to me twice already but not with the original hard drive that came with the ps3, I changed mine to a 500 gig drive which had the problems.
the bad news is that you have lost everything that you saved onto the drive and need to reformat and reinstall the ps3 operating system.
If you go through the system settings there is an option to format the drive. Do that.
Then you need to get a USB flash drive, and follow the steps below
Download the update and save the file to a compatible storage device such as Memory Stick, Memory Stick Duo, a USB or PSP.
Before starting, use your PC to create a folder named "PS3" in the storage media or USB. In this folder, create a folder named "UPDATE" (the folder name is case sensitive and must appear in capital letters). Once the UPDATE folder is created, download and store the update for PS3 system software.
Once the update saved, remove the storage media and connect to your PS3 via the slots under the slot cover, or USB, depending on the storage medium used.
Once the storage media connected, go to Settings on the home menu of the PS3, select System Update, then update via Storage Media. Select the storage media connected to the PS3 installs the update data stored there.
Good luck.
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
I am trying to use a USB stick in safe mode to update the system software on my ps3 to 3.50. im doing it this way because it will not update via internet without stopping and encountering error 80710723. i...
The fact you're using a Macintosh system should have absolutely no bearing on your memory stick displaying the data for your PS3 to see. What may be the cause, though not very likely, is the format of the memory stick itself. You must first make sure you didn't accidentally change the format from FAT32 while saving the update to the storage. Another possibility is that memory stick may not have been formatted as FAT32 to begin with, which isn't very likely.
Check this first before continuing on. Once this part is settled, or if there are no changes necessary, proceed to the next section.
The next thing you must do is properly and immediately back up your game and save data before applying the update just in case something goes wrong. Once you've completed this part DO NOT enter safe mode again, instead, allow your PS3 to start normally and load all settings and data before proceeding to the next step.
From this point go to Settings > System Update > Update via Storage Media. Press X on the next screen when the system "sees" the data, accept the User Agreement, then start the system update.
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
Xbox 360 system will not reade any kind of storage format, like hard drive or flash drive in the usb slot.
If you have the Spring 2010 console update installed on your 360 console, you have to configure the USB device it before it is recognized by your Xbox 360 console. Connect your device, go to My Xbox menu, go to System Settings, then choose Memory. From here, select "USB Storage Device", and choose "Configure Now".
Your device will need at least 1GB free storage, and your console can use 16GB maximum of all attached USB storage devices total. Move the slider to configure the space to use & press the A button to set. Your USB device should be listed as a storage memory unit now!
May 09, 2010 | Microsoft Xbox 360 Console
I am trying to update the firmware on my psp and I keep getting an error message 80010005 or 80020321 that the memory stick could not be read. I was first getting the message with a 1GB memory stick with...
80010005=device / media not found equipment / media not found (Memory Stick or Memory Stick format is not the format does not recognize, may be a bad memory stick)
You may need to buy a new Memory Stick.
Nov 29, 2009 | Video Game Consoles & Games
PSP Update -- Memory Stick could not be read.
ok if the stick is to small it wont work but what are you really trying to do! mod it well here is how you do it!!!!!!!!!!!!!!!!!
http://forums.afterdawn.com/thread_view.cfm/688507 read about five comments down!!!!!
Jun 13, 2009 | Sony PlayStation Portable (PSP) Console
Reading "The Memory stick could not be read" 80010005/80020321
hi,
format it with windows: right click on your memory stick letter and format !
Dec 15, 2008 | Sony PlayStation Portable (PSP) Console
Cant upgrade my ps3
maybe you didnt download the update data to the memory stick, maybe you downloaded it to your pc. Next time download the update data to the memory stick and not the pc.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
49 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
