Question about Sportline 330 Step Pedometer
How do I change a battery in the Sportline Pedometer 330? How do you open the battery section?
1. I cannot open the unit to get at the battery. I do not see any place to pry it open. 2. Once open, what kind of battery and how do I replace it?
  • 121 Answers
SOURCE: i can not find replacement headphones
Have a look at the headphone jack for size. I imagine the jack is the common size for most personal stereo headphones so it should be easy to replace. If you have a personal stereo then try the headphones from that. If the jack is a different size then I'd take the pedometer to a music store and check it against a few different types of headphones..
I don't see it being much of a problem though..
Posted on Oct 21, 2009
SOURCE: Missing a battery for a Sportline Model 342 Pedometer.
Same problem here. If your pedometer is rectangular, with slanted window, LR 44 battery should work.
Posted on May 10, 2010
  • 3 Answers
SOURCE: Sportline 347 pedometer- need instructions.
http://web.archive.org/web/*hh_/www.sportline.com/manuals/347.pdf is where I found the manual. Good luck!
Posted on Jan 01, 2011
  • 10 Answers
SOURCE: Hello, I have a Sportline Digital Motion Sensor.
Do you mean the screen is blank or you cannot remember how to program it? Was it working perfect until you replaced the Battery?
Make sure the battery is inserted with the positivet side up?
Manual is here: http://www.sportline.com/manuals/370.pdf
Replacing the battery: 1. Unscrew the battery compartment cover on the backside of the unit using a small Phillips screwdriver and remove the cover. 2. Remove the exhausted battery from the unit, and insert a new battery (be sure to place the positive (+) side of the battery is visible, facing toward the battery compartment cover). 3. Replace the battery compartment cover on the battery compartment and fasten the screw (CAUTION: do not over tighten).
Posted on Jan 02, 2011
  • 1114 Answers
SOURCE: I am having problems with identifying the battery for the Sportline Electronic Pedometer 350. When I check the Sportline site, they have a 350 pedometer pictured, but it is not the model I have. The
Vinnic Alkaline Button Cell L1154 (A76, LR44, AG13, PX76A, GPA76)
L1154 is the battery number. Listed above are equivalent battery numbers.
Posted on Mar 26, 2014
Battery for a 340 sportline pedometer
The battery for a Sportline 340 Step and Distance Pedometer are any of the following: AG12, LR1142, SR1142, SR43 or 386 or equivalent.
Sep 20, 2012 | Sportline 340 Step and Distance Pedometer...
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
Dec 14, 2010 | Sportline 370 Traq Motion Sensor Pedometer...
How do you change the battery on the Sportline, fitness pedometer 360?
The battery hatch is at the bottom of the pedometer. Just slide the hatch open with your fingers and then pry battery out. Put in the new battery in the same orientation (positive up on most). I find shaking the pedometer works to get the battery to fall out. If my fingers don't move the hatch, I use a small flat blade screwdrivers.
I hope this helps.
(on my pedometer (a similar model) the hatch is on the back with a slot to slide in a finger nail and wraps partway around the hinge)
Aug 08, 2010 | Sportline 15 Function Total Fitness...
Oct 23, 2009 | Sportline Exercise & Fitness
How do I change the battery in my 345 Sportline pedometer
the battery is under the front cover. Pop it open with your fingernail or a coin. It uses a CR2032 button cell battery.
Jun 19, 2009 | Sportline 345 Electronic Pedometer
Sportline 330 Step Pedometer Logo
238 people viewed this question
Top Sportline Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
