Question about Refrigerators
Poured a beer and noticed temperature reading of 56F. Compressor not running. Notice a periodic clicking sound.
  • Gary Matyko
    Gary Matyko Dec 13, 2014
    The Beer Meister rep told me the start relay failed and told me how to remove it. Took about five minutes and new part is in the mail. Hopefully, this resolves the problem for $13.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The clicking sound is the compressor overload tripping out and resetting. For whatever reason, bad capacitor, bad relay or locked up compressor....the compressor is not starting. Of course it could also be overheated due to a defective condensor fan motor or extremely blocked condensor coil.
Posted on Dec 13, 2014
Testimonial: "The Beer Meister rep told me the start relay failed and told me how to remove it. Took about five minutes and new part is in the mail. Hopefully, this resolves the problem for $13."
SOURCE: Keg freezing!!!!
I have had this product for 2 months and this just started happening to me also.
Posted on Jun 12, 2008
Maytag317
  • 1136 Answers
SOURCE: clicking sound coming from thermostat
Hi, The clicking noise sound like a clock ticking? If so, it is probably you defrost timer. The defrost timer has a motor on it that sounds like a clock and has four wires that go to it..
This is what I would check first.
Vic
Posted on May 10, 2009
TampaNative
  • 778 Answers
SOURCE: clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Posted on Jul 14, 2009
  • 68 Answers
SOURCE: Beer keeps freezing....Compressor/fan runs non-stop...
the thermostat sounds as though it is faulty if it is frosting the entire eveaporator and not cutting out
Posted on Sep 22, 2009
aasc
  • 1606 Answers
SOURCE: Refrigerator compressor and fan keep running
The frost on the tubing , indicates a " cap tube separation " . To repair this , you will need to strip the insulation from the tubing , install wire ties , tying the small cap tube , to the larger tube , about every 1 / 2 " , from the top to the bottom . Then use aluminum tape around the complete tie area , to hold in the heat , and wrap again , with several layers of duct tape , or foam wrap . If this frost gets to the compressor , this means liquid is getting inside the compressor , which kills the compressor . Hopefully , you have caught it in time . If you see a " green powder on the tubing , it's probably too late to repair .
Posted on Oct 21, 2009
The nf90 does not seem to be pushing cool air. what needs to be checked?
Hi Anonymouse!
Please check first the compressor for something like working. If it only vibrates, you notice a high temperature in it. If this hapens, just replace the capacitor of the compressor... a white tube with 2 wires in one side and a possoble screw on the other (tipical values for europe is 400VAC in USA 200VAC and capacities from 4 to 20uF.
If the compressor it´s running, and you notice one of the pipes slightly cooler than the other, well, then you need to load gas and a help from a pro with proper equipment!
Good luck
Jul 16, 2016 | DeLonghi Heating & Cooling
Why is there water leaking under the dash
If it's leaking near the glove box, it's probably the heater.
If it leaks at the foot of the driver it may be a clogged drain near the windshield wipers under the hood. Also could be a clogged drain around the sun roof.
First you can test the drains with a cup of water poured in the drain holes. You should see the water draining out under the car, usually near the tires.
They can be cleaned out with a little bit of air from a compressor.
Hope this helps.
Feb 28, 2015 | Ford Bantam Cars & Trucks
Ac won't blow any air
Good Morning David - Here are some simple troubleshooting tips to help resolve this issue:
If the outside temperature or inside temperature is below 60 degrees, the unit may not run.
Confirm that the unit has power to it.
Check the power cord connection to the wall outlet is secure.
Make sure that the house circuit breaker has not tripped.
Make sure the unit is turned off, Press the TEST button, you will notice a click as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping and the fan will continue to run during this time.
If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Jul 09, 2013 | Frigidaire Heating & Cooling
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
The refriderator had been making clicking noises for quite a while and i s wondering what is was, every ten minutes or so it sounds like a motor in the back clicks on and vibrates very loud for about 6...
That sound you hear is your compressor trying to start. You will notice that the freezer temperature will begin to get warmer, while the fresh food side "seems" ok, but it wont for long. Now the problem might be the compressor itself, or the start device which starts the compressor. You will have to either buy a start kit and hope that is it, or bite the bullet and call A Fast Local Refrigerator Repair service and have them test your compressor.
Dec 10, 2010 | Refrigerators
Air conditioner compressor runs - freon is up to proper level....not cooling??
BOTH High and low readings should be checked to have a better idea of what is going on with an AC system but based on the limited information… the compressor is not engaged or is not pumping. Below are some things I would check;
1. Check the high and low gauge readings with the AC on & set on MAX/Recirculate, middle vents with the engine at 2,000 RPM’s, blower speed on high.
2. Check the vent temperatures with a thermometer from the middle vents, far right & far left vents?
3. What is the outside temperature at the time the readings were taken?
4. Check to see if the condenser fan blowing strong?
5. Notice if compressor clutch is cylcling excessively.
Could be overcharged, not enough air going across condenser fins, compressor not pumping sufficiently… BOTH gauge readings are really needed to get a better idea.
Below are normal car AC pressure readings with 134A.
Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI
Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor
Thank you for using fixya and good luck, keep me posted. Be glad to help you get your A/C running again soon.
Jun 12, 2010 | 1999 Chevrolet Silverado 1500
Side By Side refrigerator ED5PHEXMQ00 Model #_ Click
The clicking noise may be the overload located at the compressor. If so the compressor start relay, start capacitor and overload may need replaced. Have you noticed any change in cooling or freezer temperatures? Sea Breeze
Nov 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Clicking, buzzing, compressor too hot, thawed out
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
