I need activation code to setup video component for hp
How to activate all inputs on samsung tv
read your manual,you need to give us more info for more help
May 09, 2015 | Samsung Televison & Video
How do i find the right web-site to enter my code for roku?
If you want to enter your Roku code then you can click on this link
my.roku.com/link and still if you are facing any kind of problem regarding Roku then click here Click here to get the solution for that.
Mar 06, 2015 | Roku Streaming Stick
How can I activate my Roku code
Roku is an interesting media player; it streams the multiple types of data like audio, video, etc. at a time. Roku has many amazing features and thus many users were using Roku. Roku is an easy way to get entertained. It has many channels, shows and many events.
Roku Activation
    ·Activating your Roku device is an easy and step by step process. Follow the following procedures
    ·First Plug your Roku in power source and then connect it with HDMI port.
    ·Then select your preferred language and then go on with network configuration.
    ·Then proceed connecting your Link code with your Roku device
    ·After Roku Activation then Setup your device.
    ·After activation you can enjoy either free or paid channel.
Nov 16, 2014 | Roku HD Player (N1100)
How do I activate the component out on the Marantz SR 6007?
You need to go to Menu/Input Setup/Input Assign. In the column labeled COMP, assign the Component Inputs (1-RCA through 4-RCA) to the various Sources.
You may need to go to each Source and turn Video Convert to On. Select an Input, such as SAT. Go to Menu/Input Setup/Video/Video Convert and select On.
Aug 20, 2014 | Marantz SR 6007 AV Network Receiver
WHERE DO I TYPE IN MY ACTIVATION CODE TO ACTIVATE NETFLIX?
If you're trying to setup Netflix on a Roku, a BluRay player, or other video device the device gives you the access code and an internet address on Netflix to enter that code from your computer.
Mar 09, 2014 | Computers & Internet
Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Jan 19, 2009 | Onkyo TX-SR606 Receiver
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
 Grubhead
Grubhead
