Question about Refrigerators
On my LFX25960 ST, I cannot remove the filter by turning anti clockwies
There is a filter cartridge that filters the drinking water. I need to replace it once in 6 months. I have done this process many times without any difficulty. But this time the filter in the fridge will not turn 1/4 turn to get it removed. How to solve this problem?
  • Kenneth Sampath
    Kenneth Sampath Dec 12, 2014
    I just now tried an idea to warm up the area near the tip using a hair dryer( using a low setting and carefully applying air. After a minute , I turned the filter anticlockwise, it turned and became loose.Thanks for all the people who responded to my initial question.
    Master:
  • 379 Answers
Sorry to hear that. Most filters must be depressed slightly then turned. if there is a lot of pressure on them they may not want to turn. If it is possible turning off the water and then pushing a glass under the water dispenser may relieve the pressure enough to remove the filter. Hope this helps.
Posted on Dec 12, 2014
Testimonial: "Thanks for your suggestion. I tried turning off the water supply and pushing it also. It did not work."
How to restore lost water pressure after replacing undersink filter?
make sure the filter is going the right way.They have one direction.
Jun 20, 2015 | GE GXRLQR GE SmartWater Inline Filter...
How does a water purifier work?
A water purifier works through the process of reverse osmosis. Water purifiers cleanse water by passing it through a series of filters. This helps remove large amounts of contaminants and other harmful chemicals
Jul 09, 2012 | Camping, Backpacking & Hiking
Black & White Particles in Water
Those filters are behind the grill, down at the bottom of the refrigerator. You will need to turn it 1/4 turn, counter-clockwise then pull out. With your make and model number go to Lowes or Home Depot and get a new filter. After installing it take the time to run about 5 gallons of water through it before using for drinking water. (This clears the filter of an anti-microbial agent used during manufacturing.) This will fix your problem.
If this is helpful to you, please take a sec to rate me. Thanks!
Don
Apr 04, 2012 | Refrigerators
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
Jan 26, 2011 | GE Refrigerators
Need to find water filter on my amana model scd23vw refrig.
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
Aug 16, 2010 | Amana Refrigerators
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
