Question about Brother Office Equipment & Supplies
My brother printer LC75 won't print says on the screen error no paper feed reload paper press start I did this still won't print
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 906 Answers
In order to solve this issue try the below mentioned step:
1. If you have a photo paper tray installed just above the main tray, pull it back towards you otherwise it blocks the paper feed.
This should resolve your paper feed issue.
GuruAid.com
Posted on Dec 12, 2014
checkitright
  • 1362 Answers
SOURCE: brother printer mfc-7420 will not print
Manual feed is a by-pass tray (not the paper tray,)
in this particular model it looks like one of hte slots in the front. put a paper in and see if it grabs it.
you should be able to cancel out the job by pushing stop/cancel?
1-check the tray to make sure the paper size is correct
2-make sure it is set for tray not bypass
Posted on Jul 30, 2008
  • 4 Answers
SOURCE: HP 1280 Error message
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
aicaxz
  • 511 Answers
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Posted on May 30, 2009
  • 3 Answers
SOURCE: My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Posted on Sep 17, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
I replaced the toner cartridge, but I am getting a blinking green ready light with a blinking red alarm light. will not print.
This is a paper jam error. Try reloading the paer if you can not find any paper stuck inside the printer. Then press the start button.
Dec 09, 2009 | Brother HL 1440 Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Load mpf paper
Your printer is set to default to the Main Paper Feeder, which is probably set for letter size paper. You must tell it to feed cards. On your Windows Desktop, left click mouse on START. left click on CONTROL PANEL, and left click on the PRINTERS icon. On the PRINTERS screen, RIGHT CLICK on your Dell printer icon. On the drop down menu, left click on PRINTING PREFERENCES. On the PRINTING PREFERENCES window, left click on the PAPER/QUALITY tab. Under TRAY SELECTION, choose the PAPER SOURCE where you want your business cards to feed from. Left click on APPLY button. Next, left click on the ADVANCED button. On the ADVANCED OPTIONS window, use the drop-down box next to PAPER SIZE to choose the paper size you want to feed. Press OK button. The PRINTING PREFERENCES window will now reappear. Left click APPLY, then OK buttons. After you have printed your cards, be sure to restore the printer defaults back to their original state, or the printer may jam because it must be programmed for the paper size being used. If you reload letter paper without resetting the paper size, the printer will think there is still card sized paper in the tray, and it will issue a jam or error code until the paper size is set properly.
Jul 30, 2008 | Dell 3100cn Laser Printer
I have a brother copy/fax/print MFC 5860. i am unable to print. no paper jam..the screen reads: no paper fed #2. reload paper, then press start. i have paper in both paper trays and have autoselect...
lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
May 15, 2008 | Brother Office Equipment & Supplies
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Paper jam
If Hp laserjet change rollers? If any kind of printer roller get rubber rejuvination liquid at an electronic store.
Oct 23, 2007 | Brother MFC 8500 All-In-One Laser Printer
Reload printer error
Try removing the paper tray, and look under where the paper goes. You should see a rubber pick up roller. Try cleaning it with a rag and some rubbing alcohol. The roller is probably slipping and not carrying the paper in far enough! Good luck John
Jul 10, 2007 | Brother MFC-5840CN All-In-One InkJet...
80 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
