Question about McCulloch Garden
How do I attach the carb. control wire to the lever on a mcCulloch chain saw mod.600016R eager bever?
Removed the lever.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 164 Answers
Hook wire before mounting carb
Posted on Dec 14, 2014
SOURCE: how to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
Posted on Sep 21, 2008
  • 11 Answers
SOURCE: need owners maual for mcculloch power mac 6 chain saw
try my answer to the post on McCulloch pro/mac 10-10 chainsaw owners manual... posted by denniswick on Oct 03, 2008
Posted on Feb 13, 2009
VtToolMan
  • 704 Answers
SOURCE: need owners manual for mccolloch electric chain saw
This is a tough one to find, but after some research I found the full blown tech manual (this saw is of the late 1980's vintage!)
Anyway, here's a free manual - I suggest you print and save a copy as a pdf for future use and reference, as once this gets pulled off the site, I doubt you'll be able to find it again.
http://mcculloch.motoruf.de/spell/get_file.php?filepath=/Mipl/ps100ser.pdf
You can also try calling 1-800-521-8559 and ask for the parts deparment and request a copy of the owners manual be emailed to you in a pdf format.
Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
dontbother10
  • 2220 Answers
SOURCE: set the carb for a mcculloch 3516 chain saw
Carburetor Adjustment
There are no hard and fast settings.
A good initial starting point for the "H" and "L" needle valves are 1.5 turns CCW from lightly seated.
The "T" adjustment enters here (idle speed) and there is no initial setting without a tachometer, depending on age of your saw there may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Start with a fresh mix of fuel. Put ALL of the old mix in any 4 cycle engine and start new. I suggest 50:1 regardless of what your manual says.
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; once marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
Now we adjust for performance. The best performance adjustment procedure I have found follows.
Madsens Shop & Supply, Inc. Carburetor adjustment (All saws homeowner and professional are the same)
http://www.madsens1.com/saw%20carb%20tune.htm Read step 4 (allow it warm before making adjustments).
There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
I am going to inject a little philosophy here. Undetected air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw. A sudden need for an adjustment is often indicative of a larger problem.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 09, 2010
  • 4088 Answers
SOURCE: I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Posted on Jul 23, 2010
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
REQUIRE CHAIN SPROCKET-FOR EAGER ****** CHAIN SAW
I WENT TO SEARS WEB. AND IT LOOKED LIKE YOU COULD BUY JUST THE PART YOU NEED. HOPE THIS HELPED.
Sep 21, 2014 | McCulloch Eager Beaver 2.1 Parts List
Mcculloch eager beaver chain saw
Hi Mike firstly check the air filter is clear and if so try putting some fresh gas where the spark plug goes into the block. If it fires its the gaskets on the carb. If it doesn't it's the gaskets on the block and it wont fire due to the compression being at fault.
Oct 20, 2013 | McCulloch Garden
I trying to find a bar & chain for a Mcculloch eager ****** saw. Only model numbers I find are 60012416or 12-052701. Saw had 16" bar which has broken.Was using Oragon S54 chain.
Here is a good website for finding bar and chains from the Oregon website.After you get the part # you want you can always purchase from other source.
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Hope this helps.
Feb 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch eager ****** 2318av what fuel mix does it use
chain saws are 40:1
3.2 ounces 2-cycle oil per gallon gasoline
Oct 25, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can't start my chainsaw (McCulloch eager ******) nor find parts!
******. these are a good little saw look for your local lawn mower repair shop. they should be able to get parts for it , carb kit ,chain,bar,clutch,fuel line. thats about it and you are back up and running ,, if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | McCulloch Garden
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
