Question about Garmin GPSMAP 2010 Chartplotter
The sonar isn't working.
The sonar decided to stop working while in storage. I swapped the external sonar power supply and it states that the sonar is "turned off". Don't know why and can't figure out how to turn the sonar "on".
2 Suggested Answers
cperkin1
SOURCE: will not turn on
I contacted Garmin and they had me remove the microchip inside and see if that would fix the problem. It did not. So they instructed me to send it back in for repair. They gave me a return number and then ended up replacing the unit with a new one. My unit was under a year old so it was no charge.
Posted on Nov 20, 2008
Mine has stopped working. Is there something I can do to retrieve it. It has so much on it I am worried that I have lost everything.
You can take it to a computer shop and ask them to test the drive. It is likely to be the external enclosure or the power supply to it that is faulty rather than the hard drive inside the enclosure.
If there are no lights on the enclosure, it may just be the power supply.
You could buy a new one and swap out the drive yourself.
SimpleTech Hard Drive eBay
Jun 29, 2016 | SimpleTech 250GB USB2.0 7200 RPM External...
How to fix error code 150-3039 on wiiu
Error Code: 150-3039 means there is a problem with with your external storage device. It is most common when you are using an external hard drive that does not have a separate dedicated power supply. It either isn't getting enough power or the hard drive has other problems. Try powering off your Wii U, disconnecting your external HDD, and running the system without the drive. It should work. Then power off and reconnect your external drive. If you receive the error message again then you should look into getting new external storage. This link lists Nintendo approved devices: http://en-americas-support.nintendo.com/app/answers/detail/a_id/1359/~/what-external-storage-devices-can-be-used-with-wii-u%3F
May 05, 2014 | Video Game Consoles & Games
My computer was working this morning and then when I tried to turn it on today, it is showing no sign of power to the computer. The only light that is on is the light showing that the computer is plugged...
The problem with your laptop isn't related with power supply. Even if your battery isn't working, it would have started with the help of the Charger/External supply.
The actual problem seems to be related with the Planner/Motherboard. When it stops working, it causes major problem. You should consult the manufacturer of your computer and if it is in its warranty period, they'll repair/replace it for free.
Apr 17, 2011 | Toshiba Computers & Internet
I have a 250 gb simpletech external hard drive. no. 96200-41001-077. I have used it as the time machine backup on my MacBook. It stopped backing up time machine recently. I got the message. Backup failed...
> icon does not show up on the desktop or finder
A major "clue" that one component of the external storage device has failed, namely:
* USB cable (try a different one)
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure
* optionally, the external power-supply that connects to the enclosure
Use a multi-meter to verify the voltage/amperage output of that power-supply.
(Not all external storage devices need such a power-supply.)
> can it be saved?
Partially. Disassemble the enclosure, and remove the disk-drive.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage-device. (Compare it to a heart-transplant -- same body, new heart.)
Nov 03, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a Maxtor Personal Storage 3100 80 GB Hard Drive which has always worked and listed as drive G. However, on eday it just stopped listing drive G. Everytime I connect it to my port hub or to the...
Try a different "data" cable between your computer and the external disk-drive.
If there is an external power-supply, borrow a "multimeter", and test that the power-supply is supplying power (correct voltage and correct amperage).
Try connecting it to another computer.
Disassemble it, and disconnect the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk is working.
If it still is under warranty, either your local retail store, or Maxtor/Seagate will honour the warranty, and replace it.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
May 07, 2010 | Lowrance Lms 520c 5" Screen Color External...
Maxtor 3200 personal storage will not load on my computer or any computer tried 2 other laptops - it was working but had to turn off desktop computer due to storm & then when computer was turned back...
Did you unplug the power supply for the computer and external drive seperately or simply turn off the computer? If the lights do not com on as expected for the Maxtor drive then the power supply for the drive may have been damaged. If the do it may just be an untimely failure in the drive. Did you shutdown the computer via windows or just "pull the plug" when it started storming? Fill me in on these details and I will help you narrow down the source of the problem. Chris
Jun 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External HDD not working , but can here it running
Have you tried powering it up without connecting it to the computer?
It should at least power up and do something. After that try connecting it to your PC (with the disk powered up already).
You can further check this external drive troubleshooting article, which has some tips on trying to get external disks to work.
Jules
Apr 19, 2009 | Western Digital My Book World Edition 1TB...
PS3 Power
Hi There, Unfortunately for you, it seems that whilst Attempting to use the Higher voltage power supply on a Korean machine you could have damaged some of the internal electronics within the system itself, The fuses may not have stopped all of the current reaching the Inside of the Ps3, this could mean that you would have to potentially replace your console, Unfortunately Sony won't be able to solve your issues for some reason as you Purchased the PS3 in Korea, ive helped other people purchasing their PS3's from the far east (Korea,Japan etc) and when using their home power supply which can be upto Double the voltage of the PS3s, its frazzled the wiring inside of the console.
you should still try to call sony customer support, see if they have had a change of heart and decide to help people who have purchased imported consoles only to break them due to the voltages going through them, if not then im afraid you may need to replace your console !
Hope this Helps ?!
Oct 28, 2008 | Sony Playstation 3 (PS3) Console
I have a recording software called Sonar 6 and every time i try to start it, i get an error message saying "sonar has stopped working". I have had the software for a few months and it's only just...
HAI,SONAR 6 SOAFTWARE WORKING PROPERLY IN THE MIDDLE IT'S NOT WORK OR FIRST YOU HAVE INSTALL THE SOAFWARE THAT TIME WILL NOT WORK.ANY WAY UNINSTAL SONAR AND REINSTAL IT'S WORK FINE.
UNINSTAL :
START>CONTROL PANNEL>ADD REMOVE PROGRAMS>SONAR>REMOVE.
RE-INSTAL :
DOUBLE CLICK FOR EXE SETUP PROGRAM FOR SONAR>SELECT TARGET AREA(DEFAULT C:\)>FINISH.
RESTART SYSTEM AND USE SONAR.
Jul 05, 2008 | Computers & Internet
Garmin GPSMAP 2010 Chartplotter Logo
42 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
