Many thanks52 set top box is coming up on my screen and then the word 'full' and then 'no signal'. Can anyone help with this?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Delete some content
Posted on Dec 12, 2014
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: No sound comes with the
Dis you take the TV to a Sony Service Repair Center,Who does Sony Warranty Work?
Most Problems related to Audio is in the SSB Board,Sometimes caused by poor Solder Connections on the Board, you might just need to replace the ssb board and that should solve the problem you are having. What is the Model Number that is Printed on Back of TV?
Posted on Jul 01, 2011
SOURCE: i have a 26' led LG TV , and i am using a new set top box . when i am joining the tv from set top box and going in AV mode , its showing input blocked, i can not use set top box services. please h
Please provide a model number for this TV, I would have thought being an LED tv that you wouldn't be needing a set-top box as it would be digital already.
Posted on Apr 07, 2012
Where do I find the turn signal flasher on a 1995 ford ranger?
You may need to get a shop manual to get the wiring diagrams.
You have a flasher for the hazards and one for the turn signals. They are two different circuits. It is unlikely both have failed at the same time.
One flasher should be on the fuse box under the dash and the other is probably behind the radio.
Sep 10, 2012 | Ford Ranger Cars & Trucks
No picture no sound. Message on screen 'weak or no signal' The signal is strong. Also in top corner it says - A-----2 Auto panoramic
Reset the tV to its factory settings. Refer its user manual for details. If it do not help you, visit the site named 'Electro-help' for more details. You might ahve to enter its service mode option to reset it to its factory settings. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 06, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When I turn my TV on, it comes on and says 'no signal' then after about 5 seconds, automatically switches its self off... any idea why?
Most sets will shut down very fast if no signal at all.
If you can before it shuts off try to change input to one of the rear audio video inputs that has something connected to it and turned on.
Failing there and if using a box of some type for signal--unplug it and the set both for a while---plug back both and let each try to boot up.
A total loss of signal or a glitch with the set or a box can confuse the TV set's Microprocessor.
May 30, 2012 | AOC L32H961 32 in. TV
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
Samsung television LE40A559P4F i cannot expand the picture to fit full screen whena picture is broadcast in 4.3 foremat ive tried the picture settings but cannot get the picture to fit the whole screen
When in 4:3 format you cannot generally change that setting.. unless your TV gives you a widescreen "Over-ride" as the aspect ratio is "Set" in programming as the signal is decoded...
Jun 03, 2011 | Televison & Video
I am play vcr audio is ok but disply not in the screen vertical backgrond is black & full screen only two white line equali so main display problem so pls help this problem sir some body help me.
I think you are seeing the tuning screen for TV's to be tuned in. Look round the back of the VCR for a switch called TEST Signal. If it's ON set it to off.
May 11, 2011 | Televison & Video
Every time I use my component video, the screen is cut on both sides. I wonder if it can go full scene or wide screen. Need Help.......
suggest you check the signal source settings. Eg, if it is a set top box driving that input then check that device picture settings are set to widescreen (16:9) format.
Aug 10, 2010 | Panasonic PT-47WX51 47" Rear Projection...
My analogue tv doesn't do anything when connected to the new set top box. The scart is connected and the aerial also. Are there some anologue tv's that can't receive the digital signal? I already have 1...
Have you checked that your aerial is connected into the set top box & not into the TV? The aerial signal has to go into the set top box & then the box will be connected via your Scart cable into the TV. On the TV you will need to select the Scart input ie. AV1. This should give you the set top box incoming signal, you might then have to tune in the box by following the on screen instructions. Hope this help.
Nov 02, 2009 | Televison & Video
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
