El manual no tiene los 4 digitos como ago la funcion .
Amigo como hago q. el t.v. funcione
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 12, 2014
SOURCE: I have a screen viore LCT37V66HM AND I I
you can find the original remote @ newpartsource.com
Posted on Mar 21, 2010
pabloloco
  • 2335 Answers
SOURCE: alguien tiene el codigo para la tele daewoo e la
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Daewoo TV's are: 0451, 1661, 0092, 0672, & 0623
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Posted on May 08, 2010
mayradiaz
  • 19 Answers
SOURCE: esta prendida la tele y
Hola mi nombre es Mayra Diaz con DISH Network. Muchas disculpas que est? teniendo estos problemas con el sistema. Por favor, me puede describir un poco m?s de lo que aparece en su pantalla. Aparece un mensaje usualmente puede que aparezca un n?mero de tres dijitos ala mano derecha de la pantalla. Si no ay ning?n numero si me puede dar mas detalles del problema q est? teniendo con mucho gusto le ayudar? con su problema.
Posted on Jan 15, 2011
kimberlyesco
  • 184 Answers
    Verified Fixya Pro
    SOURCE: tengo una television sharp y no se como
    Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
    Posted on Apr 06, 2011
    SOURCE: Como Programar mi tv Sylvania?
    tengo 1 control steren modelo RM-8000 y no puedo programarlo en mi tv sylvania. ¿que puedo hacer?
    Posted on Aug 05, 2011
    Como enlazar un control remoto IR 103602 con una caja receptora DishDVR510
    Juan Carlos Hola, se que ha este punto quizas no necesite asistencia con la programacion del control. De todas maneras le dare los pasos a seguir en caso de que los llegue a necesitar en un futuro. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control
    Nov 20, 2012 | DISH Network IR Remote Control
    Como hago que funciones el asistente y el scaner de la impresora lexmark x2250
    La guía para el X2250 de Lexmark usuario de la impresora le puede dar instrucciones más detalladas sobre cómo utilizar las características de la impresora y funciones.Puede descargar la guía del usuario del sitio web de Lexmark en http://bit.ly/mEpFyZ.
    Nota: Esto se traduce con translate.google.com.
    May 10, 2011 | Lexmark X2250 All-In-One InkJet Printer
    Mi radio clarion DB328R tiene escrito la palabra SECURITI ,necesito saber cual es el codigo de mi radio para que me funcione como deberia,xf gracias
    Generalmente el codigo de radio esta en las ultimas paginas del manual de usuario: sino, con los datos de serie y modelo podria obtenerlos en la tienda del vendedor.
    Suerte.
    Mar 05, 2011 | Clarion Car Audio & Video
    Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
    Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com
    Feb 28, 2011 | DISH Network IR Remote Control
    La Alarma de mi Sebring 98 se desconfiguro de Cuando le remplase Las Pilas Como La sincronizo o Como Hago Que funcione Otra Vez o desavtivarla por completo
    Trata de cerrar el carro las ventanas manual mente sin el control the botones y luego cuando este todo cerreado cierre con la llave del lado del chofer y espere un minuto y luego abra con la llave sin el control the botones trate eso suerte.
    Aug 11, 2010 | 1998 Chrysler Sebring
    Tengo una asus y no puedo escribir la letra enie.
    para que pueda meter caracteres con la combinacion alt - (numero) tiene que utilizar el key pad numerico,
    en un laptop para poder utilizar el keypad numerico (letras: u, i, o ; j, k, l; m, <, >) necesita utilizar la tecla "fn" y la tecla funcion que activa el key pad numerico (en mi caso es la tecla f11), en su caso puede ser diferente, mire los symbolos en las teclas de funcion, hay un simbolo que asemeja en teclado numerico diminuto.
    por ejemplo para meter la letra "ñ" presione lo sigue
    1. active el keypad numerico tecleando una vez y simultaneamente "fn" y f11 (o la tecla que active esta funcion en su teclado).
    2. ahora si teclee alt y manteniendo presionado alt, teclee uno a uno las teclas j, o, u las cuales ya deben estar activas como numeros 1, 6, 4 respectivamente.
    Apr 11, 2010 | ASUS Eee PC 900 Notebook
    NECESITO CONFIGURAR MI CAMARA EN LA COMPUTADORA Y NO PUEDO....
    pero tienes el cd?, de todas maneras yo estaba de vacaciones y deje el cd en mi casa, pero conecte la camara al computador de un amigo y las vaje de una vez, sin habere instalado el software(CD), luego cuando llegue aqui a mi casa instale el cd y el programa se llama arcsfot photoimpresion 6, despues tuve problemas para ver el video que habia hecho, pero tuve instalar quicktime, bueno si alguien puede dar mas informacion, a mi me gustaria saber mucho mas de la camara, porque me aparecen iconos como un avioncito, una rueda, tambien tome una foto y tiene sonido, si alguien sabe todas las funciones que no estan en el manual mi correo es indytu@hotmail.com clocas ref.camara
    gracias
    indira
    Jan 12, 2009 | General Electric A835 Digital Camera
    Cde 9841 r
    Bueno,el codigo de colores es el siguiente:
    AMARILLO 12v+ memoria (este cable debe tener voltage todo el tiempo)
    ROJO 12v+ accesorios(este cable va al switch de encendido del carro)
    NEGRO Negativo AZUL(solo)Antena electrica
    AZUL/BLANCO enciede los amplificadores
    BLANCO +altavoz izq.frontal Blanco/negro -altavoz izq.
    GRIS +altavoz derecho frontal GRIS/negro -altavoz derecho
    VERDE +altavoz izq. trasero VERDE/Negro -altavoz izq.
    VIOLETA +altavoz derecho trasero Violeta/negro altavoz derecho
    Te recomiendo revisar los cables y los altavoces que no esten haciendo corto en algun lugar.
    Jan 22, 2008 | Alpine CDA-9847 CD Player
    Televison & Video Logo
    26 people viewed this question
    Top Televison & Video Experts
