Question about Ovens
My fan assisted oven not working checked element ok
The element the model is a servis
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
First check the fan working motor f^%$£d
Posted on Dec 12, 2014
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    SOURCE: Faulty Daniela oven
    Hi Fiona, here is the service department number 1800886010 or the manufacturers number is 0296041226
    Hope this helps
    Pam
    Posted on Oct 23, 2009
    barkencoa
    • 3463 Answers
    SOURCE: My oven wont heat up light and fan work I have
    Even though the element look's o/k, it is more than likely faulty, more so if the fan is working o/k.
    The only 100% test to make sure if it is faulty, is to test it with a meter.
    In my experience I would advise you to replace the element.
    Please rate my solution.
    Thanks.
    Posted on Nov 03, 2009
    • 174 Answers
    SOURCE: my cooker won't heat up
    remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
    Posted on Jul 23, 2010
    How do i replace bottom element in blanco oven model bso632
    Hi Ron.
    Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
    Dec 19, 2011 | Ovens
    How do I replace the bottom oven element in a CDA CD 907 double oven
    ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
    Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
    May 10, 2011 | Ovens
    Hi, the oven is not working in my Creda Collection freestanding cooker. I have had the element tested and proved to be ok. Also the fan does not move. The timer is set to manual. Can you assist?
    If the element is okay and the element and fan aren't working together then it will be a problem further up the line. The next question I would normally ask is is the electronic timer in manual mode. When you turn the oven on does the oven indicator light come on?
    Feb 17, 2011 | Ovens
    OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
    I would suggest that the oven element is faulty
    This is located at the rear of the innner oven compartment behind a removeable cover.
    Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
    Smeg Oven
    Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
    Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
    Fan assisted oven is not heating up
    Hi.
    Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
    Please `rate my solution.
    Thanks.
    Jul 28, 2009 | Ovens
    Cannon oven not working
    If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
    Please rate my soluti9on.
    Thanks.
    Jul 14, 2009 | Bosch HBL 5032 Electric Single Oven
    The fans arn't working, have checked the element both visually and with a meter it's ok - any ideas? The cooker is approx 17 yers old, no identifable model on front, single oven
    if the elements work but the fans dont are you talking about circotherm main oven fan or cooling fans ? there are 2 if its a double oven ,the age of your oven suggests they are gummed up with carbon after years of use and will have seized up.
    hope this helps
    Jul 04, 2009 | Neff B1421 Electric Single Oven
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Fan assist wont heat oven
    the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
    Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
    Ovens Logo
    46 people viewed this question
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
