Question about Canon Office Equipment & Supplies
I have canon IR2870 with finisher and 3 way option when making two sided copy paper jam between 3 way door and right machine door without any scew or crashing jam code is e000-733-0001 please h
I have canon IR2870 with finisher and 3 way option when making two sided copy paper jam between 3 way door and right machine door without any scew or crashing jam code is e000-733-0001 please help
    Champion:
  • Canon Expert
  • 234 Answers
Error in communication with the printer.Check the connection with the printer.Check the power supply.Replace DC controller
Posted on Feb 02, 2015
jackboy
  • 2985 Answers
SOURCE: Canon Pixma Printer
Unload all paper. Examine the feed track for any obstruction- paper fragment - cookie crumbs. Take a vacuum nozzle to it and give it a good suck out. Now feed a heavy weight paper/thin card through. Did it do the trick?
Posted on May 23, 2007
  • 153 Answers
SOURCE: canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Posted on Apr 09, 2009
iservice
  • 318 Answers
SOURCE: Right-side cover will not close, springs are disconnected.
Normally the right cover hooks break off and causes the door not to close.There is square holes in front and back of the right cover that you can use to hook the spings again.
Posted on Apr 28, 2009
goodgold
  • 389 Answers
SOURCE: Canon PC-745 stopped working.. paper jam light
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
Posted on Sep 12, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Paper jams when using staple option for more than 13 copies
There is someting I would like you do for me, I will tell you how to enter service mode and retrieve a jam code, give me that jam code, I will look it up and tell you what it refers to and what it could be.
1) Start service mode. (Press the '*' (additional functions)key, '2' and '8' at the same time, and the * key once again.)
Press the copier tab > then down the left side select jam
You will see Date, Time 1, Time 2, L, Code, P, CNTR and Size.
Write down the last 5 jam codes, eg. 0201 or 0112, OF12, 0014 whet ever the combination, if you can take down the date, two times, cntr and size, would be helpful also.
Do not go changing other settings in service mode as you can seriously affect your copier and you will end up calling a tech anyway.
Please get back to me with the codes.
May 28, 2008 | Canon IMAGERUNNER 6570 Copier
Paper misfeed
hi im jules_09.have you check the inside of the copier?open the front door then see if there a paper in the transfer the transfer is in front of you if the door is open.the check the fusing unit many paper jams happen in the fusing unit.then at the paper tray if you cannot locate the paper jam inside the machine look at the paper tray from 1 to 3.then at the side most copier have opening at the side look for the door so you can see if theres any paper stock
Nov 22, 2007 | Toshiba 2060 Copier
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
80 people viewed this question
old marine
old marine
