Question about Samsung Computers & Internet
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
I tried 1TB Samsung HDD, but it wont work, My (P4BP-MX)MB not recognize 1TB. Its simply calm & blank screen after showing bios info
    Sergeant:
  • 137 Answers
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Posted on Dec 22, 2014
Testimonial: "U R right. Ill check it out. Thanks."
jackboy
  • 2985 Answers
SOURCE: SAMSUNG SV0411N HDD SHOWN ONLY 7.85 GB
you seem to have a hidden partition Have you used FDISK ? this can be downloaded just do a search You then need to remove all partitions - you seem to have only formatted part of the drive.
Posted on Jun 02, 2007
  • 1019 Answers
SOURCE: SP0812N HDD 80Gb
this mainly depends on The Operating system, if your using Windows 2000 or above it should,nt be an issue.
sometimes there are limitations on 2 hard-drives sharing the same IDE channel on the mainboard.
Try putting the second hard-drive on the secondary motherboard slot, with it,s own individual cable.
If non of the above works, it,s possibly not formatting correctly.
you,ll need a program that zeros then formats the drive.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 22, 2008
SOURCE: Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
Posted on Jul 19, 2008
mdsaeed67
  • 849 Answers
SOURCE: Sata drive not detected
just no other solution except upgrading BIOS properly
Posted on Oct 27, 2008
zzptichka
  • 95 Answers
SOURCE: Bootcode - hanaro1
Most likely drive has firmware corruption. Here's some more info.
Posted on Nov 08, 2008
Can i use 1 TB in P4BP-MX?
Purchase a $20 external USB drive case or SATA Card at Frys.com and install it.
Your OS needs to support the size also. The Firmware on the drive may not support the slower speeds also.
Dec 11, 2014 | Samsung Computers & Internet
My asus p4ge-mx-uaykz motherboard has two slots for installing ram right now i am using 256mb can i upgrade it to 2gb?
Yes you can upgrade to any DDR that is rated at PC2700/PC2100/PC1600 and non ECC. Up to 2 gigabytes.
May 17, 2011 | ASUS P4GE-MX Motherboard
WHICH RAM WILL SUPPORT P4B-MX MOTHERBOARD
DDR SDRAM upto 2 GB will support your motherboard
see full specification of your motherboard visit Here
Jan 12, 2011 | ASUS P4BP-MX Motherboard
Is it asus p4bp-mx motherboard supports DDR RAM with speed of 400 Mhz
I think it acan accept this type of ram but it will run on 333mhz.
Aug 25, 2010 | ASUS P4BP-MX Motherboard
Where can i download driver mother board P4BP-MX? non use program
Go to:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Then select "motherboard" "Socket 478" and then P4BP-MX (or 2.0 depending on which you have). Then select your OS, this should take you to a screen with the available drivers.
May 04, 2009 | ASUS P4BP-MX P4 Prescott/845GV/FSB...
How much hard disk GB support in p4bp-mx
Hi araamudhan12,
Its your choice. The motherboard will function with either size hard disk drives. The 160BG drive will store more information than you might think. So the question you'll need to ask your self is, do you really think you'll come close to filling up a 500GB hard disk drive. Most users install two drives. One as the primary & the second as an extra storage drive & to back up the primary drives data in case the primary has a problem. When looking for a hard disk drive, go with the drive or drives with the longest warranty.
When installing a new drive & the new drive will be your primary drive. Disconnect the 40GB drive. Allow windows to format the drive & install windows from scratch. Once windows is installed & completely updated you can re-connect the 40GB drive & copy all your personal data back to the new hard disk drive. When your sure all the data from the 40GB drive has been copied over. Install another 160GB drive as your back up drive / storage drive. Keep the 40GB drive just in case you missed data that you though you did not need. The Asus P4BP-MX motherboard can run, two Ultra DMA 100MHz hard disk drives.
Have more question, post here.
Mike
Apr 11, 2009 | ASUS P4BP-MX Motherboard
Howmuch hard disk GB support in p4b-mx
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
auiioo5
My hardware upgrade
all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
Mar 18, 2008 | Computers & Internet
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
