Intelliseat stopped working. New remote doesn't help
The lower three lights of the five on the top right corner of the remote lit when any button of the remote is hit. But the seat is not responsive. I ordered a new remote and the same problem persists. I tried to unplug/replug the power to the seat. I changed the batteries of the remote. Nothing works. Please advise. Thanks.
  • Jeffshu Dec 13, 2014
    I ordered and received a new remote control from Amazon. Unfortunately it behaved exactly the same as my old one. I figured the remote might not be the source of the problem. I unplugged the power to the seat again and waited overnight. In the morning I re-plugged the power to the seat and my old remote could control the seat again. Now I recalled that the problem occurred after our housekeeper cleaned the seat a few days ago. She might have used too much water and caused the malfunction. It worked again because the unit is dry now. I am pretty happy with the result. Amazon would not allow me to return the remote control. I will keep it as a spare part for the future. If you experience the similar problem, maybe it is wise to wait out a few days before any repair attempts. Good luck.
SOURCE: Remote won't work
I would try 'waking up' the remote-Take the batteries out,press each button once then put the batteries back in.See if that works.
Posted on Dec 31, 2006
SOURCE: new Sceptre 37" LCD TV does not turn on
normally the a-v cables are color coded the white goes with white the red goes with red and yellow goes with the yellow and when putting it in the dvd player if applicable it should be the same way did your tv come with a manual showing you how to hook it up
Posted on Aug 09, 2007
  • 4 Answers
SOURCE: Remote stopped working
http://www.fixya.com/support/t320518-bose_321
Posted on Jan 13, 2008
  • 476 Answers
SOURCE: I can't get my remote
It's unusual for these remotes to break down, but they often suffer from bent contacts in the battery slot.
When the battery is inserted with the tray, if makes contact with a spring terminal on the main board, and a spring terminal at the back of the battery.
First check that the replacement battery is the correct type. If the replacement is too fat, then the board spring has probably been flattened, otherwise the back spring has probably been pushed in.
Either way, its quite easy to fix.
Board Spring: using a thin wire, such as a paperclip or precision screwdriver. gently lift the two contacts from the back until they stay up from the board.
Back spring: using the same tool, hook into the loop on the contact, and gently pull forward.
This will ensure that proper contact is made when the battery is inserted.
Don't worry if you pull the contacts too far, because the battery will push them back.
In this case, remove the battery tray
Posted on Mar 14, 2008
SOURCE: Vizio L32 tv
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Posted on Aug 13, 2008
Im looking for intelliseat toilet temperature sensor
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat, Bidet Seats ...
https://www.amazon.ca/IntelliSeat-Ultimate-Bidet-Electronic-Toilet/dp/B0050EJBQ0
  1. Cached
IntelliSeat - the Ultimate Bidet Electronic Toilet Seat in Bidet Seats. ... Bio Bidet BB-i3000 Premium Dual Temperature Bidet Toilet Seat, White ยท 4.3 out of 5 stars 18. CDN$ 179.00 .... Maybe the sensor on the Seat is not working? I am contacting ...
Intelliseat Bidet Toilet Seat - Proper Wash
www.properwash.com > Electronic Toilet Bidet Seats
  1. Cached
  2. Similar
IntelliSeat, is one of AMDM's featured innovations bidet toilet seat, and after one use ... Toilet sensor permits operation only when skin contact is made ... Water Heater; Endless Warm Water; Heated Seat (adjustable temperature); Increased ...
AMDM IntelliSeat the Ultimate Bidet Electronic Toilet Seat - Amazon.com
https://www.amazon.com/product-reviews/B0050EJBQ0
  1. Cached
However, if you have a newer elongated toilet, the Intelliseat will probably fit just fine. ... Maybe the sensor on the Seat is not working? ..... Both seats have LED indicators for seat temperature and water temperature, but only the Intelliseat has ...
Intelliseat is a must for modern toilets - Pilot Bidet
pilotbidet.com/intelliseat-is-a-must-for-modern-toilets.html
  1. Cached
  2. Similar
IntelliSeat is one of the most advanced toilet apparatuses and after one use you ... These sensors can sense the presence or absence of a human body on the ...
=$= AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w ...
https://betojhkitchenbath.wordpress.com/.../amdm-intelliseat-the-ultimate-bidet-electro...
  1. Cached
Mar 20, 2013 - AMDM IntelliSeat - The Ultimate Bidet Electronic Toilet Seat w/ ... Water Glow LED Faucet Light with Temperature Sensor Three Optional Colors ... intelliseat toilet temperature sensor Google Search
Dec 04, 2016 | Ovens
The remote for intelliseat doesnt work, even with brand new batteries. Any ideas?
My remote worked but the blower would not respond. If that's the issue, take the label off the remote (the corner by the heater button) and put a piece of aluminum tape over the contacts so there is a better connection. I also got a new one from AMDM (under warranty then) but I am still using the first remote I fixed. AMDM customer service: 1-800-778-1450
Feb 13, 2015 | AMDM Intelliseat - The Ultimate Bidet...
Hello i lost the remote control booklet and i need the code for an rca tv. i have the gray 4.00 remote control ge/ jc022 the number on the inside is rc24914-d 3852
Use the Built in Code Search and never look for a code again!!!
  • 1 Turn on the device (e.g. TV, VCR or DVD) for which you wish to program.
  • 2 Press and hold the "Setup" button in the middle of the remote, under the "On/Off" button. Hold the button until the indicator light on the top left corner of the remote lights, then release the button.
  • 3 Press and release the button with the label of the device you wish to program. The indicator light will blink before remaining lit.
  • 4 Point the remote towards the device. Press and release the "On/Off" button every two seconds until your device turns off. (You may need to press the "On/Off" button up to 250 times before the correct code is found.)
  • 5 Press the "Enter" button on the lower right side of the remote control when your device turns off. The indicator light will subsequently turn off.
  • Nov 04, 2010 | Televison & Video
    My 550 remote stopped working. The light under "activities" goes on, the bastteries are good, but nothing else works. Please help!
    Please try re-installing the firmware.
    1. Log into the Logitech Harmony Remote Software on your computer
    2. Click on the Downloads button at the top-right corner of your screen
    3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
    4. Once the firmware upgrade is complete, click on the Update Remote button
    5. Test your remote.
    Jan 24, 2010 | Logitech Harmony 550 Remote Control
    Forgot how to set remote up with tv
    For the RCA RCR412S you might find that it doesn function like the manual says it should be functioning. In my case the Direct Entry method didn't work with my Sharp TV or my Panasonic VCR. I then had to figure out how the Automatic Search method worked because the manual was incorrect. Here is how to program the RCR412S using the Automatic Search method:
    1) Turn on the component you want to control (TV, VCR, DVD)
    2) Press and hold BOTH the component button on the remote and the On-Off button
    3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
    4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
    5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
    6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
    You can download the manual here:
    RCR412S Manual
    Mar 19, 2009 | RCA Universal Remote Control
    I would like to know how to pro. 103602 ir remote
    In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
    Mar 15, 2009 | DISH Network IR Remote Control
    What button is the address button
    What is thecode for rca tv
    Try this method as it is a bit easier than keying in different codes. One thing to consider is that not all TV's are compatible with the remote so if you have changed the TV out you may experience this issue. In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
    I am having problems programming the remote
    Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/dow... http://www.jascoproducts.com/support/dow... Hope this helps, Good Luck :) Please Vote
    Jul 01, 2007 | GE JASRM24977 Remote Control
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
