Question about Lanier Office Equipment & Supplies
Lanier error code 00
Switched two drums..same wrench error code when trying to make a master
    Champion:
  • Lanier Expert
  • 208 Answers
That is the master clamper area. Take off the rear cover. From the rear it is on the right. There is a motor and a rack gear that moves to open the drum master clamper when removing and loading a master. With the back cover removed, try to make a master while watching that assembly. You can also put the drum in and drive the motor by hand to watch and see if opens the drum clamper.
Posted on Dec 14, 2014
3 Suggested Answers
ODCaloney
  • 260 Answers
SOURCE: the wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Posted on Mar 16, 2009
  • 1126 Answers
SOURCE: Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Posted on Sep 23, 2009
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Sep 10, 2011 | Ricoh Aficio 450 Copier
Our Lanier copier is showing a wrench. What could be the problem?
Could be an error code, is there a number preceded by an sc displayed on the panel?
Aug 01, 2011 | Lanier 1205 Copier
What is error code cs990 in lanier 5645
change the drum unit and initialize the ID sensor -thanks
Jan 05, 2011 | Lanier Office Equipment & Supplies
Sep 23, 2009 | Lanier Office Equipment & Supplies
Getting a red ''wrench'' symbol, spits out blank page when making copy, error message to turn off/on main switch which we have done, but doesn't clear the error. The red ''wrench'' symbol keeps coming...
Press "clear/stop" and "8" at the same time. An error code will be displayed as long as these two buttons are held down. What is the error code? Let me know, please.
Sep 01, 2009 | Lanier Office Equipment & Supplies
Lanier 5245 it has an error code SC329-00,
Did this happen after the machine was serviced? this is typically when it would occur...."LD pitch error"
Perform LD pitch adjustment with SP109-3, and SP109-4 (400dpi & 600dpi) or the ribbon cable on LD unit is blocking proper movement of the unit.
Apr 18, 2009 | Office Equipment & Supplies
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
32 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
