Question about Royal Office Equipment & Supplies
I have a Royal 1940's magic margin typewriter. It was working fine, but now the carriage always slides to the far left and does not stop. Occasionally it will catch halfway through the movement, but w
I've tried clearing the tabs and resetting the margins
  • 454 Answers
It sounds like you have a stuck down tab key or the carriage release is stuck down
Posted on Dec 13, 2014
  • Alan Richter
    Alan Richter Dec 14, 2014
    Thanks, any tips on how to fix this?
How do I change the left margin on this typewriter?
There are two levers at the back of the carriage with a small arrow mark on them. You normally depress them and slide. A bell rings when the carriage approaches the right margin.
Using typewriter
Oympia SM3 deluxe italic manual typewriter
Apr 17, 2016 | Office Equipment & Supplies
Deluxe. Why doesn't carriage move all the way to the right?
seems like there is a stop that needs moved , but it's been 55 years since I had a typewriter so you just need to look for it
Aug 29, 2015 | Royal Office Equipment & Supplies
How do I set or change the margins on my Royal Safari typewriter?
If you are following user's manual instructions to reset the margin and can't, maybe your Royal Safari is defective? Insist trying and if still no luck try to ge a typwriter repairman, a species in near extintion by now.
Jul 02, 2015 | Royal Office Equipment & Supplies
Royal FP Typewriter's left Magic Margin is not holding. How can I fix it?
There is a spring that holds the margin together locking in place, most likely the spring is gone or the teeth are broken.
Mar 01, 2014 | Royal Typewriter Circa 1957 Fp
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
L.C. Smith & Bros. typewriter No. 5 Margin setting
Make sure the carriage lock switch isn't on (presuming it has one). A carriage lock switch prevents the carriage moving when in transit (say, inside its case). These switches are usually located on the right hand side of the carriage, slightly underneath.
Gordon
Jul 19, 2010 | Royal MS 25 Typewriter
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
150 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
