Question about Mitsubishi XD500U DLP Projector
What cables do I useand settings for xd500u to hook up dvd or cable box? Can't get an image but works with my laptop using monitor cable
Works great with laptop via RGB, but no DVD image/signal at all with RCA 3 plug for dvd or cable box hook up.Not as easy as I thought.Haven't tried an S-video cable.
SOURCE: mitsubishi hc1500 banding
If you're using the VGA port, you'll see the banding because it's not really showing 720p, it's doing scaling (I'm not sure from what resolutions it's scaling). So, even though you're using VGA at 1280x720, the scaling is still going on and it's showing the banding.
You have to use HDMI to get true 720p.
Posted on Jan 30, 2008
Marrie
  • 563 Answers
SOURCE: MITSUBISHI HC 100 PROJECTOR
Hi there
First try to bypass the box and put signal directly into the Projector from the source - i.e. DVD Player
If the signal still doesn't pick up , try using a different cable.
If the problem is solved , then your Converter Box is faulty.
If the problem still occurs then you might have a faulty Mainboard - as all the inputs on this Projector is situated directly on the Mainboard.
Hope this will help you !
Posted on Mar 27, 2008
jahting
  • 70 Answers
SOURCE: No output from projector when DVD player into RGB ports
do that again and press input on your projector.
Posted on Oct 08, 2009
SOURCE: xd500u prjector image upside down
Use your remote to access the image menu(menu button). scroll to the Mirror Invert selection. select invert.
Posted on Nov 11, 2012
  • 25 Answers
SOURCE: I have a Mitsubishi sl4su projector that I use for
s video doesn't carry sound so you will have to use phono plugs too
Posted on Dec 08, 2012
Can't switch back to cable after using dvd
Disconnect the DVD---if using a box disconnect it also---run cable to the tv directly to see if box is causing the issue.
If works with cable direct to set unplug the box and after a short wait plug it back to let it try to reboot.
If reboot does not work consider having the box swapped out.
May 28, 2012 | ESA ET432E TV
Have a nx1932w; worked fine until this morning; turn on the monitor (using it as tv) the logo is in black and white and it says no signal - can't even get menu button to work.
the most common problem with LCDs today is failing electrolytic capacitors, especially in the power supply section. Look for bulging, leaking, blown or missing capacitors and replace them.
May 17, 2012 | ViewSonic NX1932W LCD Monitor
Monitor says no signal and will not run a dvd
It could be a couple of things. If this monitor is hooked up to a computer, it could be a bad video card. A video card is easily fixed on a desktop, if you're using a laptop you're probably out of luck.
If it's hooked up to a DVD player, check that the cord to the monitor is hooked up properly (make sure the connection goes from the "Video Out" on the player to the "Video In" on the monitor and that all connections are tight, not barely hanging on). If that doesn't work, try a new cable.
This is probably insulting, but also make sure that the monitor is set to the right channel if it's multichannel. For example, if your DVD player is hooked up to HDMI 2, make sure the monitor is set to use HDMI 2 for signal.
If none of these work, it's time to find a tech-happy friend that can inspect everything visually. Hope that helps!
Feb 21, 2012 | Dell Computers & Internet
VIZIO P50HDTV10A PICUTURE FLICKERS IN AND OUT CONTINIOUSLY WHILE WATCHING TV. PICTURE DOES NOT FLICKER IF WATCHING VIDEOS.
HI, you can do these troubleshooting steps and get back to me..
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jun 17, 2011 | Televison & Video
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
I cannot record a TV show on my DVD-VCR375, niether to a VCR tape or DVD disc. Nothing but static results. The recording mode of my machine works OK in dubbing from tape to disc.
You have to be sure you are running your video source THROUGH your VCR. Just because it's on the TV doesn't mean your VCR can see it. How are you hooked up? Cable? Satellite? If you are on basic cable you have a tough problem. This VCR does not have a tuner built into it. You will have to use a television or other device that has a tuner and a "MONITOR OUT" or "VIDEO OUT" plug in the back of it. This is usually a composite, or yellow-colored cable. You will run this cable into the yellow plug in the back of the VCR that says "IN." You also need "AUDIO OUT" jacks from your television or other device. These are usually red and white cables. Plug these cables into the red and white "IN" plugs on your VCR by the yellow one. If you are using something like satellite where you have a box, you will want to plug in your satellite receiver to your VCR using the same colored cables. If you have to plug in the cables that once went to your television, you need to turn your television to the input you normally use to watch your VCR. You may need to change inputs on the VCR. You should then see your satellite or cable box on the television set. It is now running THROUGH your VCR. Hopefully, at this point, you are hooked up correctly. If you are using the "MONITOR OUT" method, you just have to have faith that it's working. If you're using the other method you can actually see it on the screen. Now tune to whatever you're trying to record and press the record button. Be advised, however, that many DVD/VCR recorders have protection detection built into them (particularly on the DVD side) and your recording may stop part-way through and tell you that "this content is protected." If you have other questions post back. Best of luck.
Apr 24, 2011 | Video Game Consoles & Games
Input connections are not working properly. Some are black/white, some flash, some dont work. How do I fix it?
is your main antenna / cable (or cable box) connected to tv/monitor cable in...the monitor is on Ch 3...do you have dvd player or vcr...these devices must be set to cable / ch 3 also...and hook up to aux 1 or tv 2 depending on the jacks avail on the back of tv (please note if you are using a dvd recorder premium ch like HBO is and will be scramble)
Jun 14, 2010 | Polaroid 4011-TLXB LCD TV
The image expands off the screen of my HD tv
Look in the menu for an image adjustment option. This is used to center or adjust the given image. Try a different type of connectiong from the cable box to your TV. ie; if you are connected by component connection, try AV or HDMI to test. If that doesn't work, look at the cable box settings (call your cable company for instructions) or have the box replaced if defective.
This is common for PC connections but not for cable.
Dec 21, 2008 | Televison & Video
Hooking it up
To get the dvd working hook up to amp with a optical or coax lead to your amp digital in,set out put on dvd to give 5.1 sound,next put a phono cable from cable box to tv input on amp or sat input,now put phono cables from tv audio out to tv or other free input on amp.Set sound to prologic2 and you should have surround sound for all.
hope this helps.
CABLE GUY.
Jun 05, 2008 | JVC RX-6030V Receiver
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Mitsubishi XD500U DLP Projector Logo
48 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
