Tablets & eReaders Logo
D
Darla Solberg Posted on Dec 12, 2014
My Samsung 8.9 model GT-P7310 is running slow, what should I do?
It is just running very slow
Michelle Shaffer
Level 1:
Habit-Forming:
  • Contributor 21 Answers
  • Posted on Dec 13, 2014
Michelle Shaffer
Contributor
Level 1:
Habit-Forming:
Answers
21
Questions
Helped
2885
Points
32
I have found an app clean master that I like. it scans for security, to boost and to clear away redundant files, files that you cant open , files you dont use(with your permission of course) it helps immensely. good luck
Kindle is running slow. How to fix?
If your Kindle is running slow, here are a few things you can try to fix it:
  1. Restart your Kindle: This is one of the easiest and most effective ways to fix any performance issues. Simply press and hold the power button for 20 seconds until the device turns off, then turn it back on.
  2. Remove any unnecessary content: If you have too much content on your Kindle, it can slow down the device. Remove any books or files that you don't need.
  3. Clear cache and data: Clearing the cache and data can help to speed up your Kindle. To do this, go to "Settings" > "Storage" > "Cached Data" and tap on "Clear Cached Data."
  4. Update the software: Make sure that your Kindle is running the latest software version. To check for updates, go to "Settings" > "Device Options" > "System Updates."
  5. Disable Wi-Fi and Bluetooth: If you're not using Wi-Fi or Bluetooth, turning them off can help to improve performance.
  6. Reset your Kindle to factory settings: If none of the above solutions work, you can try resetting your Kindle to factory settings. To do this, go to "Settings" > "Device Options" > "Reset to Factory Defaults."
Keep in mind that some older Kindle models may experience performance issues due to hardware limitations. In that case, upgrading to a newer model might be the best solution.
How do i tether my lenovo tablet to my new samsung tablet
App drawer > Settings > Connections > Hotspot & Tethering
Note that some carriers disable hotspot, but you can still tether with a third party tethering app like Barnacle.
My tablet has started running really slow and sometimes freezes up. How can I fix?
hi Debbie.
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
How do I make my tablet run faster?Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authorityhttps://www.androidauthority.com/11-tricks-make-android-run-faster-414542/Search for: How do I make my tablet run faster?
or go to this link should help you out some more.
tablet running really slow Google Search
2answers
My Samsung GALAXY Tab 8.9 model GT-P7310 is running slow, what should I do?
I would recommend deleting apps that you don't use any more and pretty much just anything that you don't use. Also, try downloading an app that checks for spyware, malware and viruses because those can cause your tablet to slow down.
3answers
To many pattern attempt
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
To many patten attempts
35helpful
4answers
Can Samsung GT-P1000 Galaxy TAB update to android 3.0 or 2.3?
YOU CAN GET UN OFFICIAL MOD I.E FOR ANDROID 2.3 ON YOUR GALAXY TAB.
ANDROID 3.0 IS AN DIFFERENT O/S ALTOGETHER AS IT REQUIRES DUAL CORE PROCESSORS.
TRY IN FOR SAMSUNG TAB 10.1
Can get my archos 5 to conect to my android phone
If you mean to connect your Archos to your Android device through Wi-Fi, than, yes, you can! But, only if your android device supports the tethering feature. For example if you have an Android 2.2 (Froyo) device than you go to Settings->>Wireless & networks->>Tethering & portable hotspot and tap "Portable Wi-Fi hotspot". From the Archos, go to the the Wi-Fi settings and connect to the network you've just created. If you do not have the tethering option available, you should find out if your carrier or device manufacturer has an update for the device. Hope it helps!
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
