Question about Sunbeam Humidifiers
My reset button keeps coming back on after cleaning and refilling, how do I reset it?
Shutting it down, unplugging it for an hour then restarting it, the reset button keeps coming back on and the water isn't releasing into the resovior
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Reset light keeps coming on humidifier
I am having this exact same problem, have you found a solution?
Jan 22, 2012 | Sunbeam Humidifiers
I have the MA0800 and I have a CF flashing on the display. How do I get rid of this code? If it requires a clean filter, then how do I reset this code once I have a clean filter?
Change the filter then unplug the unit from the electrical outlet and the code will be cleared. Just shutting the humidifier off won't clear the code, it has to be unplugged from the power to clear the flashing CF.
Jan 21, 2011 | Essick Air MA0800 Humidifier
Unplugged unit, now it won't turn back on.
is the float stuck in the down/empty position? Otherwise look for a ciruit breaker that you can reset
Feb 21, 2010 | Essick Air 447 302 Console Whole House...
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
I have cleaned by humidifier and changes the filter. The red cleaning light comes on and i hold it down to indicate i have cleaned it and it shuts off and will not restart. It have never done this before...
First make sure the tank is properly installed rock it a bit toi see if it is secully placed.
Then Unplug it for a gfew minutes. ther replug and reset it before you start it.
Feb 05, 2010 | Air-O-Swiss 7133 Humidifier
Have a warm air Honeywell humidifier. The "refill/restart" button is permanently on even if I refill the humidifier and the humidifier does not want to work now. How do I fix this? It seems a sensor is...
This may be due to one of two things.
1. If you turn the unit off or unplug it when you refill the resevoir, then plugging back in or turning it back on will not automatically reset the refill sensor. You must depress the restart slide switch on the bottom front controls to reset and restart the unit, or.....
2. It the refill light won't clear after refilling the resevoir or following the above step, the most likely cause of the problem is a scaled up heating element, which must then be cleaned.
I just uploaded a copy of the user manual to this site, but if you would like to download it directly, follow this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this helps!
kcomp1863
Dec 03, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
Humidifier doesn't work as it used to,,,,,
First check to see if the two water sensing probes have been cleaned. After cleaning, if the problem still persists, try the following.
There is a small thermostat switch that sits on the heating coil underneath. This thermostat is designed to prevent the coil from overheating when no water is present. What probably has happened is the switch is doing what is designed to do but has become defective and is opening and closing at a lower temperature. So what is happening is the red light reset indicator will come on because this switch opens, the coil starts to cool and the switch closes and the light goes off. Because it is defective, this is occurring when it shouldn’t, causing this maddening on/off cycle.
Fortunately, this sensor is easy to replace if you’re handy. Make sure you unplug the humidifier from power. Turn it over, remove six screws, and carefully lift the lid. Look toward the heating element and you will see a small button type device with two wires plugged into it and is attached with two screws off to the side of the element. This particular thermostat is obsolete and very difficult to find. However, there is an excellent substitute made by Stancor for around $5.00. Their part number is STO-325.
Remove the two screws and lift off the thermostat and slide the wire connectors off. Simply reverse the process for installation and be careful to replace the bottom lid, being careful not to crimp the wiring.
Dec 07, 2007 | Slant Fin GF-210W 2 Gallon Humidifier
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Humidifiers Logo
66 people viewed this question
Top Sunbeam Humidifiers Experts
Paul Sikkema
Paul Sikkema
 steve
steve
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
