Question about Garden
Why does my riding mower scalp the yard even when i have the deck raised all the way up. have new spindles and blades recently. have removed deck and reinstalled but still nothing has helped.
    New Friend:
  • 25 Answers
Check your tire pressure when your on it it will be lower
Posted on Dec 12, 2014
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Why are blades scalping on the right side?
Hi Terri:
How many blades on your cutter deck?
Seems logical that something on the right side is allowing the deck to be lower than on the left. Try parking it on a level flat surface (concrete driveway maybe) and WITH THE ENGINE OFF, lay next to the deck and have a helper raise and lower it. look at the linkages and try to see how they function, and look for a chain or metal bar with a hole in the end that is not connected. Find one, figure out what to connect it to, and you'll be cutting like a good thing.
I told this problem to my son. His suggestion was to let the air out of the tires on the high side. I think I'd prefer to find the problem
May 01, 2015 | Garden
Yardman troubleshooting
I suggest that you should remove deck, turn upside down and place straight edge or tight string line over blades from outer edges of deck frame. Use the guide strips to get even measurement. Rotate blades and measure distance from straight edge to tips at both sides. they should be the same. If there is difference from one side to the other, either the blades are bent, or if each blade is same at each end but not aligned in centre (difference in height) then the spindles need packing to make them even. Check that bearings are not loose. If you do not understand this best to take it to service centre.
Jul 23, 2014 | Yardman Yard-Man 13AC76LF055 38-Inch 344cc...
My machine does not cut the grass evenly. The right blade does not lift the grass the same as the left. New blades, new belts. Deck is clean underneath. Spindle bearings are quiet and blade turns freely....
Does the mechanism that raises & lowers the deck do it evenly at both sides, if not, is there any way of adjusting it? Where there any spacers that you might have missed before fitting the blades?
Aug 27, 2011 | Craftsman Garden
I have a 15.5 hp Craftsman Riding Mower with a 42" deck, the mower now leaves a 3inch strip between the blades and I blade cuts the grass lower on one side (scalping)
As for the stripe, you will need to change the blades, they are worn out, if not damaged outright. As for the cutting the grass lower on one side, since you are changing the blades, remove the deck and inspect the spindle/mandrel on the troublesome side paying close attention to the ears that the bolts that mount it go into, you may well find that one of them is cracked. If so, replace it. The spindle/mandrel cost a little over $60.
I hope this helps you out.
Aug 12, 2011 | Craftsman Garden
Uneven cutting, scalps
Your tires could need air, especially if it does the scalping while in a hard turn. The spindle could be cracked or the deck could be unlevel. Unless you hit something with the blades recently, I would check tire pressure first.
I hope this helps.
Jul 30, 2011 | John Deere Garden
I had hit a somewhat hidden stump on the lawn..bending the blade. Took the deck off and replaced the bent blade. Put the deck back on and now the cut seems uneven. It appears that the deck is now...
I've only had luck removeing the deck, turn it upside down. Measure blade, mark, remove blade, insert large pipe over spindle, bend in direction. Re-install blade, and do it all over and over till straight. Measure in several locations.
Aug 18, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Setting the cutting heighth on my riding mower.
sounds like you have some bent blades or spindle shafts.If not then the lift bracket on the front of the deck may be bent or the weld broken or cracked.
Dec 12, 2009 | Garden
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
