Question about Mitsubishi Televison & Video
I'm back.my mitsubishi ws-48413 tv only has a blue screen when i turn it on. Ive tried several things. I tried turning on the receiver first and waiting 10 seconds and the opposite. I rebooted the tv and the entone 450 receiver.I made sure everthing was hooked up right and hdmi was activated. I replaced the hdmi cord. I can get it to work by removing the hdmi cord from the receiver and plugging it back in while everything is on. But when the tv is turned off I'm back to no picture when i turn it back on. Also if i leave the tv on and just turn off the receiver it will come back on. help
    Master:
  • Mitsubishi Master
  • 688 Answers
There is a communication error between the source & the TV. When powering up the units, try turning on the receiver first, then turn the TV on, that way there is a signal for the TV to detect at initial start-up.
Posted on Feb 16, 2015
3 Suggested Answers
dave1645
  • 834 Answers
SOURCE: I have a Mitsubishi projection model WS-48413 that
do you get a click if not check the fuse inside next to the ac cord inside the unit
if you do have a click then your convergance amps let go you will need a tech to replace them qbout 150 dollar job
Posted on Nov 19, 2009
gopakumarg43
  • 75311 Answers
SOURCE: thanks for responding to my question about the ws-48413 mitsubishi. I'm exausted from fooling with this tv. The only other thing i can think of is I wonder if this entone 450 is compatable with thi
Just surf the site I given here. It has set-up code list; such that, it has selected from different brand remote controls; with different TV brands. The list is published in the alphabetical order of the brand name to the set. I recall that I've seen about 8 posts there, with alphabetical order of TV brand name, and the code list to each of them; with different brand TVs.
Check all the posts. You will get a suitable code; complactable to your Mitsubishi TV to Entone brand remote control. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 14, 2014
Thanks for responding to my question about the ws-48413 mitsubishi. I'm exausted from fooling with this tv. The only other thing i can think of is I wonder if this entone 450 is compatable with this tv....
Dec 14, 2014 | Mitsubishi WS-48413 48" Rear Projection...
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
Nov 19, 2009 | Mitsubishi WS-48413 48" Rear Projection...
Mitsubishi ws-65615 tv flashing timer light. tv
ONLY 1 of 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD TECH
Oct 13, 2009 | Mitsubishi WS-65615 65" TV
My mitsubishi ws-48515 will not show a picture , ive tried to reset it and i cant use front controls or the remonte just will let me turn it on with the remonte.it only shows a blue screen.
The keys on the front of the TV are probably in 'lockout' setting. Try holding the MENU key on the front of the TV for about 10-12 seconds to see if they will unlock. Let me know if this does not work.
Aug 11, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Caption
sometimes if you have a cable or satellite box as source.(if your case )then you would have to turn it off in the cable or satellite box.
Jul 10, 2008 | Mitsubishi WS-48413 48" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
