I have a maytag bravo model number MVWB300WQ2 and it making a humming noise and won't drain water. I have looked under the wash machine and took both pump off and nothing was clogged but the pump on the left when I took the black part off the white part that spin is really loss and I was wondering if it could be broke and that why it humming
  • Washing Mach... Master
  • 3,368 Answers
I think you found the problem, get another pump.
Posted on Dec 12, 2014
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
SOURCE: washer not spinning or draining
Same problem.  Water wouldn't drain, no trouble codes, door wouldn't unlock.  When the Rinse and Spin cycle or Drain cycle was selected all I got was a growling humm from the pump.  Clued in by the above postings I pulled the washer away from the wall, tipped it back so it leaned against the wall with the bottom fully exposed and removed the plastic panel covering the bottom (underneath - 4 screws) of the machine.  The small pump was just where these postings said it would be, top right of the bottom opening. Disconnect the two drain hoses from the pump. Mine were connected with hose clamps that I removed with just my thumb and fore-finger.  I had two quarters AND a nickel lodged inside the pump and was able to coax them out without removing the pump. Replaced the hoses and bottom panel, tipped upright and I was back in business - didn't even have to unplug (Its never a bad idea to do so) or disconnect the water hoses.
  • Total time spent: including searching for these posts and random dead-end trouble shooting - 1.5 hours.
  • Tools: 1 Phillips screwdriver.
Posted on May 27, 2009
  • 220 Answers
SOURCE: maytag MLE2000AYW not draining
When you removed that clog after the pump you should have gotten very very wet if that was the only clog.
 You will have to bail the water out of the tub or pull it out with a shop vac,and even then when you remove the other side of the hose on the pump you'll get a couple gallons of water coming at you,throw some towels over the motor control on the right front corner so it doesn't get wet and have more ready for the gush of water coming out.
 Throw rugs were notorious for clogging these hoses up also check the out going hose from the pump to the drain,if you have the heavy rubber hose run something through it to make sure it is cleared out.
 and if it was throw rugs your going to want to fill it and drain it several times when you get it draining again to make sure it is all cleared out of the machine,if it drains into a standpipe be careful it doesn't clog your pipes that stuff is like cement.
Posted on Sep 27, 2009
Testimonial: "Very helpful and a quick response. The advice was what was need to correct the problem. Also I appreciated the tips on what to expect."
  • 6 Answers
SOURCE: I have a Westinghouse mastermind 708 washing
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
I have a maytag bravo and it making a humming sound and wont drain water
There isn't much I can add to Gordon's Appliance solution.
thats exactly where I'd go for the solution .
Dec 11, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
Jan 01, 2013 | Maytag Washing Machines
My washer is making a rattling noise as if the water is not leaving the machine. I checked the hose...nothing....now my washer has water in it
does your washer spins?. the most common cause would be a sock caught in the pump blocking the water drain and making noise with the pump impeller.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
