Question about Building Materials
Using duraseal quick coat stain/sealer on a wood floor, how do I darken the stain color? 1st coat came out very light on white oak.
  • 5,316 Answers
Ad color stain to suit. Oh and this section is for car and truck questions. Just saying...
Posted on Dec 12, 2014
I'm using old masters espresso stain over red oak new hardwood floors. Do I need to use a sealer or will 3 coats of Duraseal matte finish be sufficient?
I would use Duroseal . Follow manufactures recommendations. Ensure that it will not impart a color to stain.
Jul 26, 2017 | Building Materials
When steaming wood floors leaves floors wet
Kathy if you are talking about hardwood floors you should NOT use any kind of steamer ever on them .
The wood is eighter oak or yellow pine most common however cherry and moghagany on high end houses and used .
But it is all what is called tung and grove and is finished on the top olny with an interior finish that dosn't work well with moisture let alone forceing steam under it it will soak into the bottom of the wood and then the wood will start to cup become uneven on open up .
The best thing you can do if you have this problem let it dry out might take some time weeks or more .
Then rent a floor sander sand it stain it and put at least 3 coats of a polyurthane over it if you use water base poly you will need more coats.
May 08, 2015 | Vacuums
How do i repair isolated "spots" or small circle gaps in my lacquer finish?
What kind of wood are you dealing with .
What kind of stain are you useing im sure its not laquuer .
What kind of sanding sealer .
And how are you applying the finish airless conventional or air assested air less and do you have an air trap for the conventional or air assested .Its more then likely you used products that were not compatiblale Its hard to say with out seeing it
Mar 12, 2015 | Deft Clear Wood Finish Satin Quart
What do I use to refinish a pine table?
Do you want it to still have the pine look?
if so, use a clear oil or sealer/varnish/urethane.
if not, stain it whatever family/species of wood you like.
then seal it.
Jan 17, 2015 | Crafts & Hobbies
How to prepare new knotty pine to accept a semi transparent water based stain
Wally, New wood should not require any prep. Although a light sanding couldn't hurt, the wood will accept your stain. Try it on a piece of your leftover wood first.
Nov 29, 2014 | Min Maw Sumpro 75 1800 Watt...
Remove mold on hardwood floor
Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
How to stain a solid wood floor
They have paint on it.If have it you have to remove old paint.Some place have machine to remove old paint you can rent.Then put new stain.
Apr 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
Loosing wood colour in exterior deck flooring, floor unused for6m
When I recoat my outside wooden seating I use Danish Oil and if the colour has faded I add a small amount of stain of a suitable colour. You could try it with the linseed oil but the Danish oil dries to a hard coating and will build up if several coats are used, allow time to dry between coats.
Regards
Alan Hood
ami-man
Apr 19, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Building Materials Logo
114 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
