Question about Uniden BCD396XT Compact APCO 25 Handheld Scanner
Clear all info from bcd396xt - Uniden BCD396XT Compact APCO 25 Handheld Scanner
Looking for freescan software
do google search on model check out yahoo group for ur model may help i have used freescan not sure iteh still on.
May 18, 2016 | Uniden BCD396XT Handheld Scanner
Hi, I am trying to program P-25 systems on my uniden bcd396xt scanner, but I cannot find the tgids to enter into the scanner.Can anyone help?
You should only have to program the CC (control channel) frequencies for P-25 systems. You should be able to pick up all talkgroups. Then you could I.D. and program only the talkgroups you want to hear.
Jan 17, 2016 | Uniden BCD396XT Handheld Scanner
Model #BCD396XT. Where can I get a manual?
Go to the Uniden site, select support, and look for the manual. You should be able to download a copy.
Jan 12, 2016 | Uniden Radio Communications
Uniden bcd396xt scanning but no sound coming from scanner
BCD386XT No sound. If it is actually stopping on an active broadcast and if you have the volume turned up (press down on volume button and release, then rotate to adjust) then the most likely cause is a failed speaker. Try a set of headphones in the jack on top by the antenna, if you have sound there it is most certainly a bad speaker. It is a very tiny speaker that is as thin as a nickel, many have been broken by a simple jar or by being played too loud by the hearing impaired. It is not hard to change but basic soldering skills are required. the speaker is available from uniden parts.
Apr 05, 2013 | Uniden BCD396XT Handheld Scanner
How to program
You may want to go to BCD396XT on your computer and download an owners manual...or call Uniden to help you program it...or take it to someone that knows how to program it......
Jun 17, 2011 | Uniden BCD396XT Handheld Scanner
Uniden BCD396XT...........I programmed my channels with my computer. I cannot get back to them...........I will pick them up when I turn the unit on then it scans public safety............
BCD396XT
While the unit is scanning the public service band (or other
preloaded like NEWS etc) press the Func button once, located on the left side
(the top one). Now within one second press the L/O button twice. This
permanently locks out that system. Pressing the L/O button only once will lock
out that band only until the next time you turn the scanner on, then it will be
back.
Jan 22, 2011 | Uniden BCD396XT Handheld Scanner
Uniden BCD396XT Compact APCO 25 Handheld Scanner Logo
91 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
