Question about Kitchen Appliances - Others
Scotsman ice maker stay in harvest - Kitchen Appliances - Others
  • 1 more comment
  • howard thompson Dec 15, 2014
    Hi Nelson Zometa, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number?
  • Ben Erasmus
    Ben Erasmus Feb 25, 2017
    It is a model AC 45
  • Ben Erasmus
    When the macine is switch on the water solinoide valve opens and compressor switch on but it stays on harvest cycle
  • 102 Answers
If it was unplug while at some point when the unit was in the freeze cycle or loss of power . It's programmed to go into harvest even if you press doesn't know if ice is on the evaporator or not...let it run its course 5 to 6 mins
Posted on Jan 15, 2015
2 Suggested Answers
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman cm3 does not harvest
First i need the model number CM3 is a controller number and is it a blue or black controller. then i will be able to help you.
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
your sump level control sensor is not reading the water level drop to go in can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Scotsman ice machine problems
harvest thermo must not be working, or harvest cycle motor
Jan 03, 2014 | Kitchen Appliances - Others
Scotsman cme1356 stays in harvest too long
First make sure the machine is clean and sanitized. Also make sure the harvest assist plunger is engaging. Is the hot gas valve opening up? is the pump running water over evap plate.
Aug 09, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Kitchen Appliances - Others Logo
415 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
