Question about Refrigerators
Ge GSS25SWASS water dispenser not shutting off
    Novelist:
    Scholar:
  • 166 Answers
The solenoid valve that supplies the dispenser is either stuck open, or has a piece of scale or debris stuck in it, preventing it from closing all the way.
The former can happen if it's getting power when it shouldn't be, such as a bad switch on the dispenser, or a bad control board. Use whatever kind of electrical tester you have and find out whether it's getting power in the off position. If it isn't, see next paragraph. If it is, then call a repair service.
The latter can happen if there's no filter on the line supplying water to the fridge. After removing the plastic discharge line, look into the valve opening to see if there's any visible debris. If there's not. Replace the valve. If there is, and you want to try cleaning it out, you'll have to activate the valve then blow compressed air through it from the supply side of the valve (disconnect the copper supply line). If that doesn't clear it, replace the valve.
Posted on Dec 12, 2014
    Top Expert:
  • Refrigerators Master
  • 34,255 Answers
The valve could be defective.
3 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: water dispenser will not shut
Cut the water off wherever your water cutoff is. Behind the fridge or under the sink. Your water inlet valve is stuck open and will need to be replaced. It's on the back where the water supply connects to the fridge.
Posted on Apr 15, 2011
Testimonial: "Thank you!"
aasc
  • 1606 Answers
SOURCE: I have a GE refrigerator and the water dispense
Replace the water valve .
Posted on Jul 18, 2009
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
I have GE refregrator (side by side) GSS22JERF, water is continuesly flowing through the water dispenser . finally I have to shut down water intlet to refregirator. what will be the issue?
You are describing a problem to be either your water valve is stuck open or you may have air in the line creating a siphon. If with the water on, if you unplug the water valve in the back, does the water stop flowing? If yes, problem is door switch, if not, its the water valve not closing. Have you recently replaced the water filter? Did you flush out the air? If not this is called a siphon effect and can cause the water dispenser to run after dispensing water.
Those are things I would look for.
Sep 14, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My frige does not dispense water or ice
If when you attempt to dispence ice/water the light dims and the refrigerator seems to shut down unitl you let off the dispenser the main board is bad. http://appliance-repair-it.com/GE-refrigerators.html
Sep 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
The water will not stop coming out of the door dispenser
1 of two things. 1)the switch at the dispense flap has failed. 2) the water valve solenoid that the sitch activates has failed. you will need to pull the unit away from the wall and remove the bottom panel...on the right side you will see the valve assembly. remove the power connection to the vavles....then turn your water on...water out of dispenser means bad solenoid/valve....no water means bad dispenser switch.if its the switch you can leave the solenoid to the dispenser unplugged until you get the part.
Jun 11, 2009 | GE Profile Stainless Bottom-Freezer...
GE SxS with dispenser in door. Dispenser switch won't shut off.
that is not a problem with your switch you have a bad water valve replace it and you should be fine
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
