Question about Motorcraft 1997-1998 Ford F-150 Window Regulator, 97-98 WLR-33
How do i remove the drivers door panel to replace the door light switch(97Ford
Trying to get info on how to remove the drivers door panel on a 1997 Ford F-150 to replace the door light switch
    New Friend:
  • 17 Answers
First things first. You sure the light switch is located in the door and not the "door" jam ? That being said. hear goes. First you will need to remove the two screws located just under the door handle you grab when closing the door. If not electric windows the must remove the retainer clip holding the window handle in place using a slightly bent nail and pair of pliers. Push the panel inward til you can see the metal clip ring.
Then depending on the year you might have a few screws over the speaker housing. After those are removed you will need to pry up on the lower corned of the door with some type of long forked or flat screw driver. Shine a light into the space and you will notice some white looking clips. (They go all around the sides and bottom of the panel.) Those are what holds the door panel in place. You will need to pry them up one at a time till the door panel is free to move.
Now lower you window all the way down. Holding the bottom of the panel lift up til it come free of the top track where the window slid into it.Now hold it with on have lift the door hand and slid the panel off.
Once you have the panel off you will see some electric connectors running from the controls for the windows. Use a small screw driver to release the clips and pull apart. Once that is done now you are ready to remove the panel and set is aside.
Now peel back the plastic dust shield and locate the switch in question. ( you might have to temporally reconnect the panel to raise the glass to have easy access.) Once switch is replace test before putting the panel back on in reverse order. Oh, one small bit advice. Check the see if the light it self is nopt out before doing all this. And one other, make sure all the door clips are in the door panel slots and are straight. Do this before and after the panel is in place before trying to press the panel back into place. Should take about 2 hours. But once you get the hang of it. only about 20-30 minutes next time.
Posted on Dec 12, 2014
    Scholar:
  • 103 Answers
There is a step by step video on youtube for this:
On youtube - search for "How To Install Replace Door Panel Ford F-150 Expedition 97-03".
I need to know how to get the drivers side door panel off. My window is off track and I need to fix
how to remove door panel on a 97 expedition, pull up on master window switch bezel careful clips break easily and unplug the connectors, remove triangle trim piece top right side of panel pull out then up, screw behind it remove it, remove red lense plastic piece on bottom of door small screw driver careful breaks easily screw behind it remove it, remove bezel around door handle turn it to get off handle screw behnd it remove it, pull straight up on door handle gently then hard if needed, after it is loose from door remove light bulb socket from behind door panel turn it, unplug power window switch.
thats it reverse to put back on
Nov 25, 2010 | 1997 Ford Expedition
1997 ford expedition window won't go up... how do
Remove sail panel cover for mirror, remove screw. Remove window switch cover and remove screw. Remove courtesy lamp lens on door and remove screw. Remove inside door handle trim cover and remove 8mm bolt and handle. Lift upwards and remove door panel.
Oct 08, 2009 | 1997 Ford Expedition
My back windows wont go up and the doors wont lock. door ajar light pops on
Will the windows go up and or lock from the respective doors? Is this the master control on the driver that does not respond? If so remove the driver door panel ( see 97 Park Ave door lock for instructions ) and check the wireing harness located under the switch control panel, make sure all are pluged in well and are not damaged. If the wireing harness is in good repair You might want to check salvage yards for the appropiate control switch replacement. ( watch them remove it from the junker and you'll know how to install it )
Jul 08, 2009 | 1997 Buick Park Avenue
How to remove drivers door panel from 1997 Cadillac Deville.
try to look at stress point on door by handle normally two screws and under neath panel to screws also disconnect side panel for side mirror door of using panel popper
May 23, 2009 | 1997 Cadillac DeVille
What make the dome light and ajar light stays on after closing the doors on my 97ford f 250
The door adjar switch is sticking. Most of the time you can spray WD40 into the latch assembly in the door and open and close the door a few times and this will unstick it.
Mar 10, 2009 | 1998 Ford F150 Regular Cab
HOW DO I REPLACE THE DRIVER SIDE POWER MIRROR ON AN 98 F-150?
Remove the sail panel,the little panel on inside of door at the mirror.
Remove the window regulator switch plate, pry up on the front of it with a small pick or screw driver. Disconnect the electrical connectors.
Remove the top door trim panel screw that is behind the sail panel you removed.
Remove door trim panel screw at window regulator switch plate opening.
Remove door trim panel screw in the courtesy lamp housing. Remove the courtesy lamp lens.Remove the screw.
Remove the inside door handle trim cover.
Remove the bolt.
Remove the inside door handle.
Lift upward to remove the front door trim panel.
Remove the courtesy lamp.
Turn the courtesy lamp bulb socket one quarter turn and remove.
Disconnect the power mirror electrical connector.
Remove the three outside rear view mirror nuts.
Remove the mirror.
Jan 31, 2009 | 1997 Ford Expedition
Replace glass, drivers door on 1997 GMC 1/2 ton Truck ,2wd, Power windows
The door panel is held onto the door with clips but first you need to remove the screws from the grab handle on the door panel. then pop the bezel off around the inside door handle. very carefully!!! then using a clip tool pry off the peice that covers the rear view mirror nuts and pry gently all the way around the door panel until its loose then lift it up slightly to unseat the window channel strip off the door, then unhook your wires. As for the window roll it up, tape it to the door then line up the 2 10mm bolts that clamp it to the regulator with the provided holes in the door, loosen 'em up roll the regulator down and remove the window. Have fun guys!!!
Oct 28, 2008 | 1997 GMC Sierra
Motorcraft 1997-1998 Ford F-150 Window Regulator, 97-98 WLR-33 Logo
538 people viewed this question
Top Motorcraft Scuba Diving & Snorkeling Experts
jeff5may32
bobalix
Gil Shultz
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
