Question about G&G GR15 Raider Blowback, Long
My G&G GR15 raider shoots out bbs on semi and auto, however after about 5-10bb's it stops shooting them out- still makes shooting sound and air comes out so it is working but the BB's get stuck in
Took the bb's out of barrel and then tried again (same thing happens), also have charged battery and tried 4 different magazines. Sometimes it works for a little and then stops pushing out BB's, they get stuck in the barrel for some reason..??
I have a prime air roofing nailer...it will shoot one nail wont shoot any more til i open an push nails into position
It sounds like the auto feed is jammed. It just might be some dirt holding the slide from advancing or it could be a broken feed spring.
Aug 06, 2016 | Air Tools & Compressors
Crosman parts list
all bbs (true old bbs) are caliber .177
Aug 15, 2014 | Cameras
Yamaha wave raider no spark
Check plugs first ,for gaps, and cleanliness and electrode condition, check plug connectors, ht leads coil and then cdi unit
Mar 27, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
Daisy air rifle parts
check the non return valve for failure of the seat and valve. check the trigger valve for air leaksfrom not seating properly
May 26, 2013 | Daisy Air Rifles - 4841 Grizzly Camo Kit...
The BBs won't come out or shoot.its a crosman MCSR01 air gun
Seal leak in the air chamber.Need new seals
Mar 15, 2013 | Optics
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
Play hard, play safe, play with honor!
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
M92f HELP
no you can not it is spring so you have to **** it every time you want to shoot
Jun 13, 2010 | Ics Hop Up Bucking for Airsoft Guns
I work the lever to load one BB. then pump 6 or 7 times. BB will not shoot out. When I pull the trigger, it sounds like it is shooting, but no BB comes out. this is for a crosman 760 pumpmaster. it...
Can you see through the barrel? Or run a rod down the bore? It sounds like the BB is either falling out the end of the barrel or the BBs are getting jammed up in there. Do not hold your hand in front of the barrel to see if any air comes out. You might get stung with 10 BBs. Hope this helps.
May 22, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
G&G GR15 Raider Blowback, Long Logo
440 people viewed this question
Top G&G Sport & Outdoor - Others Experts
Are you a G&G Sport and Outdoor - Other Expert? Answer questions, earn points and help others
