Question about Maytag Refrigerators
Refrigerator not cold turned up setting to 7 with no change however freezer is working well
Turned setting up from 5 to 7 this is a French door Maytag refrigerator approx 10 years old
    Sergeant:
  • 166 Answers
Some things to start with. Defroster not working and evaporator is iced over. Fan that circulates air has failed. Solenoid on flapper that opens air passage is not opening.
Posted on Dec 11, 2014
Why is the freezer too cold and my fridge not cold at all
Perhaps the temp setting got turned by accident checckwhere it is set 4 or 5 should work
Jan 27, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
Our LG LFC20760S refrigerator/freezer coldness setting is stuck. The refrigerator coldness setting is showing no values at all (and I can't update). The freezer coldness setting is stuck on 6 AND 7 (and...
That MIGHT be the control board but before you order anything you should check the thermistors. The board relies on data from them thermistors. If one is out of spec or even out of spec then that throws a monkey wrench in the works. What you need is a manual which shows the locations of these thermistors and some diagnostics info. French Door Service Manual
Jan 03, 2011 | LG LFC20760ST Stainless Steel Bottom...
Refrigerator section not cooling
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2010 | LG LFC22740 Bottom Freezer French Door...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
I have a LG refrigerator LFX25980n with FF failure, how to fix?
Is the freezer cold, but the refrigerator part is not cold?
If so, "FF" probably means fan failure. The fan which moves cold air from the freezer to the refrigerator is not working properly. The fix is to replace this fan.
Oct 09, 2009 | LG 24.7 cu ft Panorama French Door...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
My refrigerator is too cold
sounds like you have a defective temparture sensor
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Both Fridge and Freezer not blowing cold air.
with the thermostat turned to its coldest setting can you hear or feel the compressor running?  Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, JT
Oct 24, 2007 | Amana AFD2535DES French Door Refrigerator
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
78 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
