Question about Bosch Dishwashers
How can I reset she44c02uc/43 - Bosch Dishwashers
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher(model # she44c02uc/43) extended wash/no drain
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control. A faulty flow switch, ntc or heater can also cause this, but not very probable.
If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony to it`s success or failure, but I`m 99.9% certain ;)
Good luck.
macmarkus :)
Posted on Feb 24, 2010
Dishwasher Does not Fill Past First Rinse
There is an anti flood valve on the bottom of the unit. IT could be sticking or have a bad connection. IT should look like a dome shaped housing on the bottom of the tub. If that is not the problem then you are looking at further troubleshooting to see if it is the contoller.
Jan 19, 2014 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Good luck.
macmarkus :)
Feb 24, 2010 | Bosch Dishwashers
Bosch she44c06 will not stop draining, what is key selection to reset and continue using machine
on mine I have to push 2 buttons at the same time for 3 seconds to cancel cycle.Check your manual under cancel cycle. However you may have a problem discussed at this link:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Oct 31, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Door latch
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Mar 19, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Error code 43
i believe if dis connect the battery it should reset the ecu
Feb 19, 2009 | 2006 Yamaha YZF-R1
Bosch dishwasher she44c02uc runtimes are getting longer
hi there this is a software problem on the pcb and the only way to fix it is to replace the pcb. cost about £80
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
52 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
