Question about Hipstreet Hip Street Titan2 HS-7DTB25-BND7 7-Inch 8 GB Tablet
Trying to connect tablet to wifi saying its not in range but laptop and cell phones are connected was told need a booster
Tried resetting modem tried calling provider
  • Hipstreet Master
  • 3,632 Answers
Could be no available connection on the radio wi fi system you may have reached maximum user capacity try turning off wi fi on one of the currently connected devices and see if tablet connects to it . Was it 802.11G the Wi fi system.
Posted on Dec 12, 2014
My tablet will not connect to my internet
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Can't connect to Internet through WiFi on Android Tablet/Phone - Asus
www.asus.com/UK/support/FAQ/1003867 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=tablet%20will%20not%20connect%20to%20my%20internet
Dec 21, 2016 | Tablets & eReaders
Samsung laptop showing connected to wifi but when try to access wifi says problem with connection
Try using the troubleshooting option that usually is offered when you get a network error message. If still does not work after that need more specific info on exact wording, Windows version, whether all wifi connections affected, etc.
Jun 04, 2016 | Samsung Galaxy Tab Tablet PC
My tablet says I am not in range when I am and will not connect to my Wi-Fi
Delete your wifi on your Tablet and retry connection. It may be a hiccup in the system.
Oct 01, 2014 | Tablets & eReaders
My tablet is saying i am offline and will not connect to Wi-fi
Firstly Check if your WIFI router is working by accessing the WIFI connection from another computer, tablet or phone.
If it does, then use the same WiFi connection settings that it has on your ARCHOS.
You could also try connecting your ARCHOS to a friend's WiFi network and if this works, change your access point parameters to similar ones.
OTHER TROUBLESHOOTING OPTIONS:
1. Check your WiFi router/modem documentation to see if it has a pairing button that needs to be pressed. Some modems have such a button that must be pressed the very first time you try to make a WiFi connection with a new device.
2. If you have to enter a password (a security code of type WEP or WPA) be very careful that you do not confuse a 1 and I (one and letter "I"), a 0 and O (zero and letter "O"), or U and V. These are common mistakes.
3. When entering a security code for your WiFi access, check the box "Show Password" which will allow you to see exactly what you are typing in. This will avoid any mistakes.
4. Some access points use what is known as MAC filtering. That means, the WiFi access point has a list of access numbers (every hardware device has a unique MAC number) which are the only ones allowed to access to the WiFi point. The person managing the WiFi modem/router should shut off this MAC filtering system to see if this solves the problem. It is recommended to shut off MAC filtering in general as this is now known to be an outdated and ineffective system for WiFi security. If you must use it, you can find your device's specific MAC address by going to Settings >Wireless & Networks > Wi-Fi settings > Menu > Advanced. It will look something like 00:16:dc:5e:9e:39.
5. Try temporarily shutting off the encryption system of your WiFi router/modem to see if the problem has to do with the encryption system you are using. The preferred encryption system is the WPA2.
Aug 14, 2014 | Archos Tablets & eReaders
Wont connect to internet even though the wifi says it is connected
It could be because of the amount of devices that are connected to your wifi. Too many devices could put a lot of weight on your bandwith causing the wifi itsself to become slower. Disconnect any devices using wifi in your home that dont need to be on every day and try reseting your modem or router. You could also use a usb cord to get a more direct connection or you might have to upgrade to a faster wifi company. If the problem still continues take your device back and get it fixed, call the number in the troubleshooting guide, or visit the nextbook website and make sure you have your device registered.
Jun 25, 2014 | Nextbook Premium 8 Se Android
Why has my tablet suddenly not receive my wifi connection; it says it is a poor connection. I have tried reconnecting it but to no avail. What else can I do? I do not believe it is the modem and the...
Hi Dolores,
You may want to try restarting your devices starting to modem ( unplug re-plug power cable for 2 minutes) then your tablet. After that try to re-connect to your wifi make sure you are not at least more than 300 ft away from modem though your tablet has a good wifi connection system already ( you should not getting this issue ). Hope it helps.
Apr 29, 2014 | Samsung Galaxy Tab 101 Tablet...
I cannot get my tab 3 which is brand new to even see my wifi at home. it says it is not in range. i have been able to connect to some free wifi in other spots. help!
I read something about manually adding a wifi spot...Don't remember where it was but try Samsung dot com
go to your wifi page and do a search will progressively getting closer to you modem... if it doesn't see it in range at all, check with your internet provider as something may be conflicting... I've had no problems connecting to my home wifi or wifi spots all over the state of Florida and I have the same Tab. Wonderful product and you will enjoy it. Also some apps are made for mobile phones only and will not work with the tabs... keep this in mind
Dec 18, 2013 | Samsung Galaxy Tab 3 7.0" - White...
My internet tablet keeps saying network problem when i try connecting to wifi
Please check your password and see the strength of the WI-Fi in your area. If this a wifi of your home wireless modem then check the modem and reset accordingly. switch off power for some time and restart.
If not check your tablet on another wifi to confirm this or if the configuration has gone off from the settings.
make sure that your password and the network is connected as seen on the lower taskbar .
Jun 06, 2012 | Nokia 770 Internet Tablet
Hipstreet Hip Street Titan2 HS-7DTB25-BND7 7-Inch 8 GB Tablet Logo
202 people viewed this question
Top Hipstreet Tablets & eReaders Experts
Lawrence Oravetz
ray gallant
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
