I have #622of5000. The battery case is destroyed because of neglect. Where do I find parts? This is my 2nd request. 205-640-6908. stewartsimpson@windstream.net
Sent
Aspire 750 power button destroyed.
I found a very (What I feel) very good "Website". There are power switches for you Laptop. I think this will best site for you. I've included the "Link" below........ However in my on experience,. Replacing the power switch requires a couple of hours and can be very frustrating. I hope this helped and the best of luck to you.
MRF
Acer Aspire One Netbook Parts Acer Aspire One Netbook Replacement Parts...
Apr 23, 2014 | Aspire Computers & Internet
Remington hc 5550, how to open it without destroying plastic cover. i.e. to replace battery. (Especially how to put off plastic part at the end of handler which hold together both top and bottom halves of...
Most of these types of units are sealed and cannot be opened without damage to the case. Even if you could open it, the battery is most likely using connections that are spot welded to it. You will have trouble getting another battery for it that has the same connections.
Oct 28, 2013 | Remington Hair Trimmer Accelerator Hc5550
Camera was briefly submerged in salt water over two weeks ago. Replaced battery with new one. Nothing happening.
If the camera took on salt water it is already to late, the salt corrodes the ic pins and eventually moves into the casing and destroys any delicate parts, the only option is replace the camera.
Apr 08, 2011 | Cameras
Hi: Somehow, I've had 2 FB Accounts for sometime (same Email address and password when logging in. The original account and the one I want to keep is under: Leslie Ryan-Pyves (this has all my photos...
Sorry, we can't help you with that since we aren't related in any way with FB. You must contact them directly by sending them a mail here
http://www.facebook.com/help/contact.php?show_form=disabled
explaining the situation and requesting the correct action from their part - something got messed up in their servers and they are the only ones with access to them. Luckily the account should have been only deactivated (if you have done it from the Account Settings) - all your info from it will be recovered from their backups and to recover them you should try to login into it from another pc (or delete the cookies from your present one). Unless of course you have specifically requested that all the data to be deleted - in that case everything is lost for good.
If this is indeed the case all you have left to do is to completely wipe the other account also, wait at least a day and then create a new account with what you need.
Apr 03, 2011 | Computers & Internet
Remote door transmitter is not working. Changed the battery.....still nothing.
does the 2nd transmitter work
if no, then your receive may have failed
if you don't have a 2nd transmitter, then you need to take your vehicle in for service and either have the failed parts replaced or best case, have the transmitter or receive reprogrammed
Sep 08, 2010 | 2008 Honda Pilot
98 5.7 4x4 trans shifts hard from 1st to 2nd and
This is most likely the first signs of transmission failure. There's not much you can do aside from getting it rebuilt. This should be a 700 R4 they're a pretty easy transmission to rebuild, however you want to do it sooner than later. Many of the parts can be re-used IF you don't let it go too long. I've rebuilt hundreds of these and I'm here to tell you that I'd rather not destroy 500-600 dollars worth of hard parts if I don't have to.
Nov 09, 2009 | Chevrolet Suburban Cars & Trucks
My bike idles and revs up ok but when I give it full throttle it dies. Is it too much or too little gas
check your fuel supply and fuel filters,especially the one which is part of the fuel tap,(these often get neglected and end up causing all sorts of strife)you may have to remove the fuel tap from the tank on some models but this is a very simple job,if you do remove the tap take care not to destroy the rubber o-ring or gasket between the tap and the tank..hope this helps
Jul 05, 2009 | kawasaki KDX 220 R Motorcycles
I'm just a girl. 99 suzuki esteem 1.8L wagon wont shift into 2nd. grinding type noise heard in first gear when accelerating from takeoff then wont shift into 2nd at all. no problem or noise noted when...
Did you check the oil level inside the gear box? Most people never service the car, so this part gets neglected. if it ran out of oil, you probaply broke it(a big repair bill).
Try putting oil(probably 90w gear oil;check a manual,internet to make sure;if you make a mistake dont worry any oil is better than NO oil).
Check the differential fluid level too;same thing will happen if you neglect doing this.
Mar 01, 2009 | 1999 Suzuki Esteem
DJ Ditty Battery?
Battery is not replaceable on this unit. Removing the outer casing will just cause components to fall out - you will end up destroying the player.
Oct 30, 2007 | Dell DJ Ditty MP3 Player
 Grubhead
Grubhead
