Question about Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
How do I set timer for on and off ?
How do I set for start and end times \
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
Set clock and be able to tell am from pm setting
The Clock uses a 12-hour cycle with a.m. and p.m.
1. Check that the oven is off.
2. Press CLOCK.
3. Press TEMP/TIME "+" or "-" arrow pads to set the time of day, including a.m. or p.m.
4. Press CLOCK or START
The Timer can be set in hours or minutes up to 12 hours and 59 minutes.
1. Press TIMER.
2. Press TEMP/TIME "+" or "-" arrow pads to set the length of time.
3. Press START to begin the countdown. If enabled, end-of-cycle tones will sound at end of countdown.
4. Press TIMER twice to cancel the Timer. Do not press the CANCEL/OFF keypad because the oven will turn off.
5. If the TIMER is running, but not in the display, press TIMER to display the countdown for 5 seconds
Delay Start:
The Start Time keypad is used to enter the starting time for an oven function with a delayed start.
Hope this answers all you questions about your stove.
Jaye
Nov 04, 2013 | Whirlpool RF263LXTQ Range
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Sep 15, 2013 | Oxo Hardware & Accessories
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to program my Woods N1506
FOR MANUAL OVERRIDE
Dec 13, 2010 | Woods Hardware & Accessories
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
FOR MANUAL OVERRIDE
Nov 23, 2010 | Woods Outdoor Lighting Timer
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
Timer
You can schedule for automatic recording, specifying the start time
and end time of recording. When the timer-controlled recording
completes, the setting is released.
In Menu mode selection... SET, On, OFFAfter selecting SET, press the PLAY button to set the time to start the recording.
Apr 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr Logo
148 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
