I have a miller 304 pipe pro and I can not get the voltage or amprage lights to come on the digital display
I have changed out display boards but. I still can not get voltage or amperage to come on the two displays
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 12, 2014
2 Suggested Answers
SOURCE: Viizio VT420M has scrambled Display, Sound, Backlight and PS outputs are all there
I would suspect the main board as well
Posted on Oct 03, 2012
I plug in my miller 304 cc cv welder, 220 voltage, the numbers flash randomly, wont balance out, wont weld, any solution
What does the voltage window display? If it is reading open circuit voltage then check your leads. You could have a front control board failed if not. You should probably take it to a miller tech to have pre power checks performed.
Feb 15, 2015 | Miller Welding Tools
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Sportsart treadmill error 7
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 04, 2014 | Exercise & Fitness
304 inverter: fan does not come on. unit overheats and stops
Hi:
On this unit the fan is on demand, but if it does never come on, you should send it to your nearest repair shop, your machine has 3 years warranty. Before you send it to the repair shop, try to reduce the operating voltage.
Good luck.
Jul 10, 2011 | Miller Welding Tools
Miller deltaweld 452 power source is reading EEE code in the voltage slot ???
Replace the digital meter board, its function is to also control the voltage to the unit and read the amps.
Jun 15, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
Miller Pro 350D and the exhaust flex pipe needed
you can buy flex hose at auto parts stores and fashion your own bends to replace the bad one
Feb 23, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Campbell hausfeld pro wirefeed welder model wf2000 makes tiny beads but will not adhere
Check inside the WFU, a switch with CC or CV will be seen, alternate between these two setting, CC=Constant current and CA=Constant Voltage.
On the back of the WFU you will see a plate which indicates the maximum amprage (input) that the WFU can accept and set the main power source to that amprage,
Oct 04, 2009 | Campbell Hausfeld Welding Tools
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
