When I plug my steel into input jacks of my amp if I step on the volume pedal it sounds as if I had a speaker blown. If I move my plug to effects jack volume is fine and speaker shows no problem. I wo
Nothing other than plug into different jacks to check that speaker is not blown. That is fine.
    Sergeant:
  • 192 Answers
Check your jack wiring connection, possibly broken/loose connection that needs to be fix
Posted on Feb 24, 2016
I have an ibanez tone blaster,the lights and all come on but no sound is made. Can anyone tell me what might be the problem?
Some hopefully easy fixes : Input jack could be the problem, or connection from the amp to the speaker. Does the speaker hum a bit with the volume up almost all of the way without anything plugged into the unit? If not, check the connection from speaker to amp.
If it does hum slightly when u crank the volume, check your input jack -- it might be jacked up (pardon the pun) and you can fix that easily by soldering in a new one.
Jun 11, 2016 | Ibanez Music
Fender Acoustisonic Jr. One day I played it at its highest volume, then turned it off. Came back to play it 20 min. later and it wouldn't make a sound. You can slightly hear the guitar buzzing when...
I would try using another speaker to see if you can get the sound back, this will help you narrow down the problem, you can also use the effect send to feed anothe amp to see if you get the sound OK.
It can be blown speaker or output stages,
Jul 08, 2011 | Fender Acoustasonic Junior Dsp Combo...
I tried to plug in a digitech bp200 pedal and then my amp went on the fritz and starterd buzzing loudly. I attempted using the effects loop section on the back of the amp with my bass direct into the amp,...
DO NOT try a guitar pedal as an effects insert via the back jacks... they are for an external line level EQ/Effects type unit. Your guitar pedal should NOT have caused any damage. Check the power adapter you are using with the BP200. The BP200 takes a 9 VAC adapter, NOT a 9VDC type common to most pedals. You cannot use one of the Pedal Train type supplies with the BP200. Also check that you have the in's and out's correct on the pedal... backwards and they will cause what you are observing.. Verify your cables are good. The output of the pedal goes in the FRONT jacks of the amp. ONLY line level drives go to the back jacks.
Jun 05, 2011 | Hartke Lh1000 Bass Amp Head 1100 Watts...
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
May 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Whole system is mute, power is on but theres no sound comming out even changing the audio input cable
Firstly make sure you are getting power to the speakers - there is usually a light to indicate that the speakers are turned on. If you DO get a light - then turn up the volume all the way and touch the green input jack with your fingers - that is the jack you would plug into the PC - when you touch the jack - you should hear a scratching sound come from the speakers - if u get NO sound - chances are that the speakers amplifier is blown (it is a small Integrated circuit that most electronic engineers would be able to repair)
Good luck
Feb 03, 2011 | Logitech Z-4 Computer Speakers
I get no sound at all when I plug in to the input and its not my lead or guitar, how can I fix the amp?
This is probably not a DIY repair. You best take it to a repair shop. Likely the power amp has failed or other common problems are broken connectors/jacks, broken volume pots, and finally circuit board cracks.
Nov 20, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
EFFECTS LOOP NOT SURE.
The send jack on your amp should be connected to the input jack on your pedal and the return jack on your amp should be connected to the output jack on your pedal. Read the manuals for both the pedal and the amp. If you don't have them you can usually find them on the websites of the manufacturers. Make sure your levels on the amp and the pedal are turned down when you plug them in.
Jun 24, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
81 people viewed this question
 Grubhead
Grubhead
