Question about Motorcraft 2003-2005 Ford Explorer Sport Trac Window Regulator, 03-05 Motorcraft
My 4x4 on my 2003 ford explore sport not engaging making clicking sound in the control module . i changed it to new one but still doing the same problem.
4x4 not engaging change control module still making a clicking noise but 4x4 does not engage.
How to fix my headlights
Search Results
    Explorer Headlight Problem and Interior Stuff - YouTube
    ? 10:53
    https://www.youtube.com/watch?v=f1j-H1dGT4o
    Jan 1, 2011 - Uploaded by justhes
    Explorer Headlight Problem and Interior Stuff ... Thank's to your movie I fix my car. .... 2001 Ford F150 Headlight Switch Replacement - Duration: 5:05. Jon Olson 10,273 views. 5:05. 2003 Ford F-150 4X4 Repair Part #3 The GEM Module ... EXCLUSIVE: 2016 Ford Explorer Sport with Mark Mills at Athens ...
    Replace 2001-2005 Ford Explorer Headlight / Bulb, How to ...
    ? 4:49
    https://www.youtube.com/watch?v=cQJrO0L_tSM
    Sep 16, 2013 - Uploaded by Go-Parts
    Replace 2001-2005 Ford Explorer Headlight / Bulb, How to Change Install ... How To Install Replace Headlight Ford Explorer Sport Trac 01-05 ...
    How To Install Replace Headlight Ford Explorer Sport Trac ...
    ? 4:28
    https://www.youtube.com/watch?v=NzMVcCsZ860
    May 11, 2010 - Uploaded by 1A Auto Parts
    How To Install Replace Headlight Ford Explorer Sport Trac 01-05 1AAuto.com .... I did this on my wifes 2003 Explorer only difference was the screw was a ... Replace 2001-2005 Ford Explorer Headlight / Bulb, How to Change ...
    2001 Ford F150 Headlight Switch Replacement - YouTube
    ? 5:05
    https://www.youtube.com/watch?v=l84h2PUHS0E
    Mar 1, 2014 - Uploaded by Jon Olson
    Headlamp Switch was purchased through Auto Parts Warehouse: ... to help me with my 2001 Ford Explorer Sport-HeadlightSwitch, but the .... Ford F150 Explorer 2000 2001 2002 Overhead Console Repair - Duration: 6:38.
Jan 10, 2016 | 2001 Ford Explorer Sport
4wd on my 2005 ford explorer limited will not turn off
opperate control to disengage while going in reverse. sounds like transfer is binding up. minimise turning especially on hard serfice while in 4wd
Nov 15, 2012 | 2005 Ford Explorer Sport Trac
My Ford Explorer Sport 1998 4wd 4ltr stopped in traffic. When I press the gas the engine revs however the driveshaft is not engaging and the vehicle will not move in any gear. I even tried putting it into...
It seems like this 98 is well known for this, i have a 98 as well and never had this problem YET? god i shouldnt have said it. but in my fuse cluster on the side of dash inside behind drivers door is a fuse in the 26 th position (10 A) that says its the electronic shift relay,electronic shift control module,power window relay,interior lamp relay,battery saver relay. CHECK THIS FUSE, also pos 27, ( 15A) it says DLR,back-up lamp switch,DTR sensor, GEM, (generic electronic module) ELECTRIC SHIFT. check this fuse also. Under the hood by the battery there is another fuse box inside there is a "POWERTRAIN CONTROL MODULE' I dont know what this is but it says what it says, it is located in the # 6 position and is a 10a fuse...." Be careful if you rev the gas as if it does engage you could do damage to drivtrain, also if someone is under,in front of or behind the vehicle and engages " POSSIBLE DEATH or SEVERE INJURIES could occur. Be safe and good luck
Jan 14, 2011 | 1998 Ford Explorer
4wd module isnt workin
First check these steps in engaging.
Stop completely, clutch in or neutral for automatics, step on brake pedal, engage 4wd, select gear. Sometimes the engage switch is connect to the brake also. I have to step onthe brake to get into 4Low on my 1993 Explorer.
Next step is to check for loose wires under the transmission. If the plug came out the trans wont know to get into 4wd.
Lastly, if you are handy, get a chiltons or othr manual and remove and clean the 4wd module.
If none of these work then the module is probably burned out, replace or take to a shop for replacement.
Hope this helps you get it fixed.
Dec 22, 2010 | 2001 Ford Explorer Sport
2001 ford explorer sport, door keypad reset
How to find the Security Keyless Keypad Code on the 1995-2001 Ford Explorer or Mountaineer and how to use the Keypad functions. The factory code is also printed on a label which is installed on the Remote Anti-theft Personality (RAP) Module. This is the module that controls the keyless entry system. It is located in the left rear quarter behind the removable panel (see photo). You will need to turn the two thumb screws counter clockwise and take the plastic panel off to be able to see the unit. A flashlight may be helpful in seeing the code. You are looking for the module and the 5 digit code on it like the one shown below.
Now that you’ve got the code I’ll tell you how to use the Keyless entry and set-up your own code.Make sure when pressing the controls on the keyless entry keypad you press the middle of the buttons to ensure good contact with the controls.
Check this for Programing the Keypad.
Hope this help (remember rated this comment).
Mar 29, 2010 | 2001 Ford Explorer Sport
99 explorer sport. Wiring from the body control module
There are several different wires, colors being blk/w, grn/lt blu, and pnk/wht. If you are having problems with the seat belt staying on, then prob going to be the GEM (generic electronic module).
Nov 24, 2009 | 1999 Ford Explorer
Won't start, starter will spin but will not engage fly wheel to crank up engine
Sounds like the starter drive is shot, best thing to do is replace starter with new or rebuild.
Jun 03, 2009 | 2001 Ford Explorer Sport
2004 ford sport trac - cruise control no longer works
This problem is most times caused by an open circuit in the rotating contact under the steering wheel, this part is called the clock-spring contact, it supplies a connection to the airbag and steering wheel controls like the cruise, horn and radio controls. I would check the fuse as well to cover the bases, it is fuse #9 in the passenger compartment fuse box, it is a 7.5 AMP
Oct 21, 2008 | 2004 Ford Explorer Sport Trac
2004 sport trac crusie control issues
It sounds like the cruise module is detecting something wrong. I would check the brake pedal switch, it might be out of adjustment or someone might have kicked it by accident.
Jun 24, 2008 | 2004 Ford Explorer Sport Trac
Motorcraft 2003-2005 Ford Explorer Sport Trac Window Regulator, 03-05 Motorcraft Logo
138 people viewed this question
Top Motorcraft Scuba Diving & Snorkeling Experts
jeff5may32
bobalix
Gil Shultz
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
