Question about Refrigerators
Have a problem with temperature with meat case
Have a problem with temperature with meat case from Howard/McCray model no. SC-CMS40E-8C Serial no. 09-26679-07 where can adjust the temperature or how to do that please
  • 28 Answers
Up, down arrows next to temperature gauge. Press set, and hold for 10seconds till temp is flashing, then adjust by arrows accordingly, up or down.
Posted on Dec 12, 2014
We recently moved from USA to UK, since the move our Howard Miller Grandfather clock Model No 611-070, Serial No MF0055050196 keeps good time, but unable to get chimes to work. ease.
We, in the UK, have some excellent clock smiths. It is probably just the mechanism needs adjusting. Have a look locally and on line for a clock smith or pop into a jeweller and ask for advice.
Jun 21, 2017 | Home
How can I find a wiring diagram for Howard McCray Model No. SC-CMS35-12?
Howard McCray might be able to supply the diagram.
Nov 14, 2016 | Cars & Trucks
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Sc-cds35-6
If you can't find the cover on the internet you might be able to have one fabricated at a local sheet metal shop.
As an electrician I have had electrical panel "dead fronts" made for customers by taking in the exact specs to the shop and had acceptable substitutes made.
Oct 29, 2013 | Howard-McCray SC-CDS35-6
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
Dec 20, 2010 | GE GSS20IEP Side by Side Refrigerator
I need to adjust water temperature, and dont have a manual. i have a 81v40d C model , 40 gal electric.
Here is a tip that I wrote to help people understand how to adjust the temperature on their electric hot water heater.
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
A laboratory freezer dont cool enough
Your freeze uses 404A refridgerant,No you can't make it or mix it.
You can make adjustments to the Cut in and cut out points on the T stat.
Please rate this a fixya
Feb 13, 2009 | Howard-McCray Step In Freezer low...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Gray meat
Sounds like the Venturi tube needs adjustment. Look underneath and fully open up the tube so the maximum amount of air gets in. As for the meat being gray, make sure that before you put the meat on, the grill has been pre-heated (with lid closed) until the temperature is pegged, and also always brush the meat with cooking oil to help insure browning. If you marinade meat, let the marinade drain off and dry meat with a paper towel.
Nov 21, 2007 | Weber Genesis Silver B Grill
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
