I have a session 400 amplifier and when I plug my steel into input jacks if I step ******* volume pedal it sounds as if speaker is blown. If I plug into the effects plug amp works fine and no distorti
Nothing at this point other than pluging into different jacks and checking for blown spesker
    Problem Solver:
  • 13 Answers
Check the graphics or effects jack. The normally closed connection maybe dirty.
Posted on Jan 02, 2015
  • 44 Answers
SOURCE: No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Posted on Sep 17, 2007
  • 55 Answers
SOURCE: Low volume on external speakers, no volume on internal
I have all the audio drivers for that model. Please let me know what operating system you are using. These are large files, around 7mb for xp.
Posted on Apr 04, 2009
drifterK
  • 4924 Answers
SOURCE: sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Posted on Aug 03, 2009
  • 13 Answers
SOURCE: speakers not working.................
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • Speaker Cable is connected to an audio port (Audio/Video port in system box).
  • Volume is MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System Properties Window)
• Select “Hardware” Tab>
• Select “Device Manager” Tab> (it shows the Device Manager Window)
• Select “Sound, video and game controllers”>
• Expand “+” symbol> (check the audio Codecs, Legacy Audio Drivers and others are not in Questioned Mark (?) symbol with yellow color. If there need to install the drivers ).
  • If not, insert the motherboad CD, browse>select audio driver>install. After completion, restart computer and check.
Posted on Dec 22, 2009
ganesh_tag
  • 106 Answers
SOURCE: my headphone jack on a HP computer is not working
first configure the front panel sound in control panel (start-> control panel )
even u have the same problem after configure the front panel,then check the wire connection of front panel.
thank u sir... Have a nice day
Posted on Apr 17, 2010
Why does my lowrey organ not make a sound after I have switched it on?
This is a generic answer for this kind of question.
When there is no sound
Check the obvious.
Is there a light on the organ indicating it is on?
  • Plug it in to a known working wall socket, switch on at the wall
  • Switch on at the organ, check light
  • Very old keyboards need a voice to be selected!!
  • Turn master volume up
  • Turn any other volumes up
  • i.e. lower manual volume
  • upper manual volume
  • swell pedals down
Sometimes a sustain pedal plugged into a volume pedal socket will mute the output, check this.
Headphones out, most headphones will turn speakers off, sometimes the headphone switch can be dodgy, work the headphone plug in an out a few times
There maybe a switch that turns off the speakers, look near the output sockets
Software volumes up, check display, if any.
MIDI instruments, check local control is ON
Still no sound?
Can you hear anything from the speakers?
Hiss or hum usually means the speaker is ok
Total silence may indicate speaker failure, but only if there is one speaker, as in older home organs, or smaller keyboards
Try headphones next, TURN Down master volume first just in case!
If there is some sound, very quiet and gross distortion then possible power amplifier failure.
If your instrument has any kind of line out as well as a headphone jack, try these.
The line output will likely be a pair of phono sockets,like you have on HiFi equipment, 1/4 inch, 6.35mm jacks, like the bigger headphone connector, a 3.5mm socket like the smaller headphone connector, or even a DIN connector on older equipment.
Connect these to the aux (or Line or CD) input on your HiFi, guitar amp or similar. (some times these outputs will drive headphones, usually you will only hear anything in the left side). If this works then it is very likely the power amplifier.
Further tests on MIDI equipped keyboards would be to see if the MIDI does anything.
If MIDI out works and there is no sound, and MIDI in makes a sound this points to local being off, buried somewhere in the menu will be local on or off, make sure it is on.
If MIDI out doesn't work then the failure is likely to be internal power supply or something else critical (not nnecessarily major).
Power amplifier failures in newer, low power, keyboards are often the power amplifier chips (i.c,s), older amplifiers may have just blown their fuses but one or more output transistors may have failed.
Cost of repair will be down to the time it takes to get to the fault, taking these to bits and putting them back can take a lot longer than the repair.!
Hope this helps, Chris the Fader
Aug 28, 2016 | Music
Static at louder volumes
All you need to confirm is to remove the connection to the guitar, remove the jack and cord to the guitar and now check if the noise is prevalent at higher volume, when the volume control is turned up. If so the fault is with the cord , the jack or the gutiar pick up insulation or internal connection or shielding.
Cross check with a seperate cord or another amplifier to confirm the case.
If the noise is from within the amplifier then it is possible there is fault in the preamplifier, fault with shielding of the inputs or the preamp, broken groung connection.
Compliments of the Season.
Dec 24, 2011 | Roland Ac60 Acoustic Chorus Guitar...
Whole system is mute, power is on but theres no sound comming out even changing the audio input cable
Firstly make sure you are getting power to the speakers - there is usually a light to indicate that the speakers are turned on. If you DO get a light - then turn up the volume all the way and touch the green input jack with your fingers - that is the jack you would plug into the PC - when you touch the jack - you should hear a scratching sound come from the speakers - if u get NO sound - chances are that the speakers amplifier is blown (it is a small Integrated circuit that most electronic engineers would be able to repair)
Good luck
Feb 03, 2011 | Logitech Z-4 Computer Speakers
The center chanel port does not produce sound and sparks when i plug the wires into the jack. all other chanels work except the center.
It seems that the center channel has DC voltage at the output terminals, center channel amplifier is blown and you need to bring the receiver into a repair shop. You can use a voltmeter to check DC at speaker terminals, all channels should have 0 volts when no input signal applied (or volume control set to minimum).
Do not connect your speaker you can damage it.
Jan 09, 2011 | Audio Players & Recorders
I get no sound at all when I plug in to the input and its not my lead or guitar, how can I fix the amp?
This is probably not a DIY repair. You best take it to a repair shop. Likely the power amp has failed or other common problems are broken connectors/jacks, broken volume pots, and finally circuit board cracks.
Nov 20, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
The screen is working perfectly fine, you can the see the image & all the channels, but the thing is that you can't hear anything at all. what should i do?
some tvs have a stick like button at the back.. check if yours have it and move it to the opposite side..
its hard to help when you dont have model number..
Oct 23, 2010 | Craig Televison & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I cant get my speakers on my computer to work
Computer speakers are specially designed for a computer desktop environment. They are smaller than normal stereo speakers and often have built in volume controls and amplifiers. In most cases, you can plug in your computer speakers and have them work immediately. Occasionally, however, you will need to adjust your computer sound settings to get them to work correctly.
  1. Step 1 Plug your speakers into each other. Most PC speakers have a detachable cord that goes between them. Powered speakers have a cord that plugs into the wall, which may be detachable as well.
  2. Step 2 126401_thumb.jpg Image Courtesy of: http://www.hardware.windowsreinstall.com/soundcards.htm Look at the sound card output in the back of your computer. If your soundcard has three colored jacks, plug into the green one. If it does not have colored jacks, plug into the one next to the jack with the picture of a microphone. Plug the power supply into a wall socket.
  3. Step 3 Turn on the speaker, turn up the speaker volume and play some music. If it doesn't work, continue to step 4.
  4. Step 4 Turn your volume up on whatever media player you are using. If the music still doesn't play, continue to step 5.
  5. Step 5 Go to the volume settings. If you are using windowsmag-glass_10x10.gif, click Start Menu -> All Programs -> Accessories -> Entertainment -> Volume Control.
  6. Step 6 Adjust the volume settings. Use your mouse to drag the main "Volume Control" slider and the "Wave" slider all the way to the top. If either of them have the "Mute" box checked, uncheck it. Try the sound again.
Nov 14, 2009 | Sony SRS-D21 Computer Speakers
Can't get sound to speakers
No preamp required. I just repaired one I got from Ebay.. There are a lot of buttons on the unit and you need to have several of them set correctely to get output. This is a powerful amp and you can blow speakers easily so be careful. Make sure the standby switch is up. Most important: The slide switch should be clear UPWARD to the L/R speaker position.
The white trim control(s) need to be up to match the input source levels. Advance the faders for the cahnnel(s) being used. Advance the MAIN to control overall volume. That should get you started.
MAKE SURE your source is plugged into the CORRECT input jack as there are "inserts" and you will get not output or very weak output if you are in the wrong jacks.
Jul 14, 2009 | Behringer POWERED MIXER, 20 CH, 400 WTS...
54 people viewed this question
 Grubhead
Grubhead
