Question about Frigidaire Washing Machines
Frigidaire washer combo dryer.......flsg60rgs0 will spin on last cycle but clothes are still soggy what is the problem.......belt is not broken
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, Sandra Brown!
Based off the information you have provided your Frigidaire washer is not spinning fully to drain the clothes. It sounds like a possible issue with the wash motor of sensor. I would suggest consulting with a professional technician for a proper diagnosis and repair to be completed. This will help to avoid any unnecessary part purchases. Hope this helps. -OOS
Posted on Dec 12, 2014
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
My washer makes a loud squealing noise when it spins, what is wrong
Hello Kathy McAlister - Typically, when the washer is making or produces a squealing sound is due to an overloaded load. I recommend running a cycle with less clothing. If issue continues, then consult with a professional to accurately pinpoint any potentially more serious issue like a faulty belt or a bearing/pulley suspension problem. The washer could possibly have broken something off in between the tub and outer portion of the unit.
Feb 23, 2013 | Frigidaire FEX831CS Top Load Stacked...
Runs a sec then says check cord
Operational Issues
  • If your Frigidaire washer won't turn on, check that the power cord is plugged directly into the wall and not into either an adapter or extension cord. Examine the water supply valve, and see if it's in the "On" position. If the water supply valve is cracked or broken, replace it. Check the household circuit breaker, and reset if tripped. Look at the fuses, and replace them if they have broken wires or are black. The motor can overheat if you overload the washing machine. It will release a rubber smell. Give it 30 minutes to cool down, and then restart the cycle. Examine the lid switch, which is located in the door frame. Replace if burnt out.
Spin/Wet Load
  • If the washer won't spin, verify that the lid is completely closed. Open up the main housing panel, and locate the pump. Take out the pump, and try spinning the pump pulley. If it won't spin, change out the pulley. Look for broken belts, and replace these components. If the clothes are too wet, check that the cycle is actually finished. Examine the drainage hose, and clean it out if clogged or if it has lime buildup. Verify that only 4 inches of the drainage hose sticks into the tub. Remove any excess tubing. If the tub is not spinning, replace the motor coupler.
Jan 15, 2013 | Frigidaire Electric Dryer
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Aug 05, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't start in Frigidaire FGX831CS0 stackable. Assumed it was a bad start switch because honey bunny had broken the knob off and was using a pliers to start it but have replaced that and still nada,...
Check the door switch. Turn on dryer as you push in on switch where the door catch is and see if it starts . when closed the pin may not be pushing it in.
Mike
Jun 05, 2017 | Frigidaire FGX831CS Top Load Stacked...
THE LAST SPIN ON A FRIDGEAIRE WASHER DOE NOT SPIN HARD ENOUGH TO PULL THE WATER OUT ANY MORE ITS A XC24017503 MDEL NUMBER 10 CYCLE
Frigidaire washers have a special belt that loses its ability to grab over time. NO other belt will fix your spin problem but the original Frigidaire belt. Fortunately for you, it is quite easy to replace. Also remember that the spin cycle is not for draining water, it is for wringing residual water from clothes while the pump is running.
So, your actual problem in the spin cycle itself.
Another factor to consider is that the bottom tub bearing on many frigidaire washers tends to rust and degrade over time producing a roaring noise. If this has happened to you, replacement is problematic and expensive, if not, you simply need a new belt.
Mar 05, 2010 | Dishwashers
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
