Question about Kubota Garden
Kubota L 4060 wont start full charg battery
My dad charged the battery full charge took it out to tractor and it wont start
    Problem Solver:
  • 29 Answers
If this is a diesel tractor. You need the glow plugs to cycle or it will never start
Posted on Dec 14, 2014
    Problem Solver:
  • 8 Answers
Try taking off the cables and shining up the battery terminals and the insides of the cable connectors with a piece of sandpaper and reattach the cables and try to start again. If this doesn't work, next try removing the spark plugs and shine up the spark area (center pin and sparking arm) with your .sandpaper and replace. If still no luck, it could be a fuel issue. You will need to check whether fuel is getting to the cylinders. Remove one spark plug and briefly turn over the engine and then shut it off. Do this very briefly for the sake of safety. If the open cylinder is wet (feel in the open spark plug hole with your little finger), it is getting gas. If it is dry then the fuel is not getting to the cylinder and there is a fuel plug somewhere in the system. This is more difficult to diagnose as it could be a problem with the carburetor, the gas line filter or the gas line may be plugged.
Posted on Dec 11, 2014
  • Edmund Perozzi Dec 11, 2014
Kubota B 1700 not charging
With everything connected and the engine running, you should see a charging voltage of about 13.5 ~ 15 VDC on the battery terminals. Engine off and and lights / or some other load on the battery should show around 12.5 VDC.
If the 14 ~ 15 VDC charge voltage is present when running, and the battery fails to start the engine; it could indicate a poor connection at the battery posts, dead or failing cell(s) or failing starter.
Have a look at the video below - even though it's about cars charging systems, it applies. Good luck!
Feb 04, 2015 | Cars & Trucks
How to know if a Kubota g2000 voltage regulator is charging
pull off pos cable at battery while engine is running check voltage 12.5 to13.5 should be it if not bad regulator
Sep 11, 2014 | Garden
A gas kubota zg327 mower that is not charging
small mower batteries only last a couple years but charge the battery and put on a volt meter check the voltage when off then start it and see if the voltage goes up if it does remove the negative battery cable and put a test light between the cable and the battery if the light lights up you have a draw unplug the charging system and see if the light goes out a bad diode in the system will drain a battery
Sep 02, 2012 | Garden
I have a travelmate 4060 laptop and I just replaced the battery through best buy with a generic one that was compatible. It is always saying 23% full. How do I charge this battery?thank you
1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
May 20, 2010 | Acer Aspire One PC Notebook
12 Volt Battery - Does it really need to charge for 18 hours?
1 hour for every ah that the battery is, so if its a 12ah battery then charge it for 12 hours
May 01, 2010 | Peg Perego John Deere Gator HPX Ride on...
Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
Is it hard on diesel garden tractors run for short time? 45 mins-1hr? kubota gr2110 or 2100
Short runs are not hard on the unit. As long as there is oil pressure and the battery stays charged your not going to hurt it at all. Kubota diesels are very reliable.
Kelly
Feb 28, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
I installed a new battery in my B6200 Kubota tractor. the tractor sat for 2 years, so I don;t if the charge light worked then or not. Now the charge light won't go out
check the voltage at the battery when its running if its charging below 13.5 volts then you have a bad alternator or charging system not working properly
Jun 05, 2009 | Garden
Garden Logo
244 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
