Question about Maytag Dryers
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start button it will run for a few seconds followed by an odor of burning plastic or similar then shuts down.
  • Maytag Master
  • 744 Answers
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Posted on Dec 12, 2014
Testimonial: "Thanks Peter. Model number MGDC200XW0. I have taken the front panel off, opened the top and cleaned the inside of the dryer with a vacuum. There was a layer of lint throughout. Please let me know anything specific I should pay special attention to."
  • Peter Goodwin
    Peter Goodwin Dec 13, 2014
    Hello Kevin, Good job. You hav cleaned off your sensors and electrical. No, that I have the model number lets get to the souce of the real problem. In the back of your dryer is a hot air distribution mafold. Nice dryerthis maifold is xternal not interal like LG models. Pull the dyer out. There are several fasterners holding the manifold on. I am sure after rmoving the manifold at the botton you will find it plugged up. Clean it out.Be careful you may find ear rings and such. The following is a picture of your manifold. Nice talking to you, your problem is solved. Until your next appliance failure.
  • Peter Goodwin
    Peter Goodwin, Gen Burnie, MD
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Gas dryer does not dry in "timed Dry" setting
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
My maytag model mdg9206bww dryer will not shut off on permanent press or delicates, it will dry somewhat but the unit never shuts off, if I put it on timed air fluff, the timer goes and it shuts off...
When was the last time you got your ducts cleaned? If they r full of lint then the moist air never gets outside and stays in the machine hence the clothes never dry. Might not solve the issue but they need to be done as they r also a fire hazard.
Aug 18, 2012 | Maytag HYE3657A Electric Dryer
No heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
112 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
