Question about Whirlpool Refrigerators
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is level, this weekend,I put a washer on the bottom hinge to raise the door up a little. There was a gap(1 cm) above the seal where cold air was escaping from the fridge. It seems a little slower to fill up under the crisper.? Also, water is in the shelves and some water is freezing. There are some recently frozen drips hanging off this upside down L SHAPED plastic piece.(looks like a 90* gutter connection filled with white styrofoam). I do not have an icemaker. it is 28* in fridge with meat thermometer.Thanks for any help :)
  • kelly larsen
    kelly larsen Dec 13, 2014
    I think I fixed it after reading other answers & links. TY. Took everything apart, huge ice dam behind removed freezer parts, filthy,clogged drain hose & algae filled drain pan. I just can't quite remember where these styrofome square spacer pieces fit into which freezer coils. I'm gonna stick them between the middle coils, hopefully this is the right place.
    Problem Solver:
  • 58 Answers
Check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Posted on Jan 03, 2015
  • 1073 Answers
SOURCE: Whirlpool Top Mount Refridgerator is Leaking
the problem lies behind the freezer back wall panel, remove the panel, the ground (green) wire on the top left corner and the icemaker
all the ice build up under the evaperator will have to be removed, a good hair drier works well, direct the air at the center hole in the bottom of the metal panel all the ice out of the center hole will need to be melted out to be a success it will take a little time. you can pour some water down the hole and if you hear it going into the bottom drain pan then the tube is clear of ice.
Posted on Apr 10, 2008
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
SOURCE: GE tFX26KR side by side leaks water onto floor
I read this on-line and it worked for me - - pour HOT bleach water down the drain once you get the ice out. I had this problem for ages and would periodically clear the ice out of the bottom of the freezer but since the bleach water went down that hole it has been clear for months. Of course I discovered my s/s had been recalled for a water problem.
The GE recalls are a joke anyway - a credit toward buying another GE product. Nope, I am replacing my GE's one at a time with a different vendor.
Posted on Jan 27, 2009
  • 358 Answers
SOURCE: water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Posted on Apr 08, 2009
  • 15 Answers
SOURCE: Water Leaking all over from Whirlpool Gold Refrigerator
I think that the seals are ruined when the seals are ruined the water will leak outside and inside beacause all of the heat from outside will gather together and will melt the ice and will make the moisture act up and boost the process of it turning to gas matter into liquid matter.
Posted on Apr 24, 2009
Why is water leaking from front of bottom freezer?
Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? You have a defrost drain blockage.
We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! Not all blocke drains act the same when your refrigerator leaks so please ask should you have questions. Please provide the model number found around the fresh food section door frame. Kenmore model numbers look like this example=> 321.1234567 If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 26, 2013 | Whirlpool Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Accumulates water on bottom floor below bins
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators!
Thanks, Sea Breeze
Jul 19, 2012 | Sub-Zero 695/O Side by Side Refrigerator
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Whirlpool refridg. accumulating water underneath the crisper drawers. I don't see where it is coming from. What is breaking down?
it is probably condensation from the shiny plastic drawers.i put a piece of kitchen roll under mine once a week...
Apr 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Whirlpool fridge ET1NHMXKT00 water accumulates under the crispers
Hhi, Yes the drain is plugged. remove the floor panel in the freezer and then the rear panel. Locate the drain hole (right side of drain pan) and melt all the ice. there is an after market drain heater kit that you will need to buy and add to the defrost heater.
It is a design problem. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 25, 2009 | Whirlpool ET1NHMXKT Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
140 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
