Question about Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
How long should the juel line be on a 40cc poulan
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
A fuel line should be long enough to teach from where it attaches to the carberator to the fuel tank but not quite touching the bottom - however the line in the tank end should have a small filter on it. You should be able to buy a replacement line for your specific saw.
Posted on Dec 11, 2014
What is the gap setting for a 221 pro 40cc poulan chainsaw
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Garden
What is the spark gap for 221 pro 40cc
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I bought a Poulan 18" chainsaw, and from the very
Poulan has had a notorious carb issue over the past couple of years. Products roll off the line needing a carb adjustment right out of the box. One adjustment is covered under the warranty at a service dealer near you. Look up your closest dealer at poulan.com. This is not something consumer serviceable as it requires a special tool.
Aug 18, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Leaks gas probloms strating
check your fuel line to the primer or the primer bulb. if it is leaking you will not prime properly and won't run properly due to sucking air instead of fuel.
Feb 21, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
I have an 18" Poulan chain saw, 25th Anniversary
Yes there is.If you can get the broken pieces out of the tank.there should be a filter on one of the broken lines.you will have too buy some gas line 3/16.take some wd-40 and spray the line.this makes it easier to slide through the hole in tank.then loop it around to gas cap hole and reinstall filter.then make sure filter is at bottom of tank and hook back to carb.
Nov 24, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I have a poulan 2550 40cc that won't run in idle
Possibly the spark plug, idle screw is set too low, air getting into the fuel line. Does it run at higher speeds but kills when trigger is released?
Dec 23, 2008 | Garden
Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT Logo
62 people viewed this question
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
