Question about Sony Mhc-rg270 3-cd Double Cassette Am/fm Mini Stereo System
Stereo plugged in, on/off button flashing red. Unplugged... tuner will play for short time then red flashing light and quits...
    New Friend:
  • 12 Answers
Sound like you have a short in your speaker wires or deck
Posted on Dec 11, 2014
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Hi! Sony tuner st-sa5es,stereo lighting is bliking, signal is very good and sound is stereo for short time and mono for short time.Ihave indoor aerial Fanfare,Thankyou.
I still think it is antenna orientation or there is interference. it probably works well on mono perfectly. if not then it is a defective tuner module inside the receiver.
Feb 28, 2010 | Sony Audio Players & Recorders
VIORE tv/dvd combo
If the red light flashes at plug in you likely have a main board that is bad. If you have to press the power button before the red light flashes you likely have a bad bad supply board. This will need to be diagnosed by a technician to be sure of the problem.
Aug 18, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Philips lcd 37pf9431d/37
I had the same thing - one long red flash followed by four short red flashes. Plugging and unplugging the power cord had no affect until I also unplugged all the cabled connections to the VCR and DVD player as well. Also, per the manufacturer's instructions, I unplugged the power cord from the surge protector and plugged it into the main wall outlet (which I tried first, but did not finally have success until I cycled the power cord unplugging process with all the cabled connections to the auxilliary devices unplugged as well).
Nov 18, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sony Mhc-rg270 3-cd Double Cassette Am/fm Mini Stereo System Logo
90 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
