Question about Dyson DC-35 Digital Slim Cordless Multi-Floor Vacuum - -
I have a fully charged battery, however the power light indicator is off. I've checked for blockages, but can't get the upright to operate.
I've tried a new charger, and cleared blockage. I checked to make sure the filter is inserted correctly.
  • Official Brand Answer
  • 2,572 Answers
Hi Barbara, it's Jack at Dyson.
In order to confirm why your DC35 may not be running correctly when fully charged, we'd need to take you through some simple diagnostic checks when you have your machine easily to hand. If a replacement part is needed, we can also confirm if this is covered under your Dyson warranty.
When you have a moment, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Posted on Dec 12, 2014
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
Feb 20, 2018 | Dyson Vacuums
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Not spraying water
Hi, I'm sure you've done this but double check that there is no blockage or kink in any of the water tube things! That might solve itXX
Jan 31, 2012 | Bissell 7920 ProHeat Pro-Tech Upright...
The filter camber on top pops and the air stops coming thru the whole vacuum cleaner. checked filter and washed said filter. Still happens. It is a loud pop and the air noice is loud. It pops when I pull...
I'm sorry to hear you're having difficulties with your DC15. From what you've described, it sounds as if the relief valve is activating - if you've already washed the filter, it may be activating due to a blockage in the machine. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=813&product=DC15-SY-STD
Although I note you've already washed the filter, you may want to take a look at the video below to make sure you've cleaned it as recommended. In normal use, this should be done at least once every 3-6 months. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you'd like any further assistance or advice, please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Jan 23, 2012 | Dyson DC15 All Floors - The Ball Bagless...
When the Dyson is upright and the removable parts to check for blockages are removed , sucking is strong. when the side one is reattached, the suction diverts to the outlet/slits on the bagless bin
I'm sorry to hear you're having difficulties with your DC14. From what you've described, it sounds as if the suction relief valve is activating because there may be a blockage in the cleaner head, or the internal hose.
The easiest way to check for and remove any blockages is to detach the internal hose by following the steps shown in the video below. Once you've removed any obstructions and replaced the hose, you should find this resolves the issue.
If you need any further assistance, please call us free on 0800 298 0298 (UK), or 1866MYDYSON.
Kind regards,
Jack
Nov 20, 2011 | Dyson DC14 All Floors Upright Vacuum...
Suction in hose okay through floor piece not working
I'm sorry to hear you're having difficulties with your DC24. From what you've described, it sounds as if the suction relief valve is activating - this is likely to be due to a blockage in the machine, or because the filters need washing.
The easiest way to locate and remove any blockages is to follow the simple steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
DC24 has two filters, both of which need washing at least once a month, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for them to dry completely before replacing them.
I'm confident that following these steps will resolve your issue. However, if you'd like any further assistance, call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Nov 13, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My dyson animal works great in upright and reclined position, but I don't get suction with the extension power hose (or whatever it's called -- the thing that can take attachments). The hose...
Sorry to hear you're having difficulties with your DC07 Animal. If it seems to be picking up well from the cleaner head, but not through the hose, it's likely you do have a blockage in the cleaner. Although I note that you've checked the hose itself already, you may find an obstruction elsewhere. The easiest way to make sure you haven't missed anything is to follow the steps shown in our online guide:
http://www.dyson.com/support/help.asp?article=114&product=DC07-SY-HEPA_US
By locating and clearing the blockage, you should be able to resolve the issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Aug 19, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction when wand is used. Checked for all blockage. If you disconnect no suction at base
Sorry to hear you're having difficulties with your DC24. Although I note you've already checked for blockages, you may wish to follow the steps shown in our support guide, to make sure you haven't missed anything:
If you've run through these checks and are still having issues, it's probably best if you get in touch with us directly so one of our experts can go through some troubleshooting over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 02, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My vac has lost suction. When I vacuum it picks up very little, but when I remove the wand hose it has good suction. We have cleaned both filters, checked for blockage in all hoses & cleaned the...
Sorry to hear you're having a problem with your DC14. Since you say you've already washed the filters and checked for blockages, it's probably best if you get in touch with us so we can run through some simple troubleshooting steps over the phone, and arrange service if necessary.
You can call us free on 08002980298 (UK) or 1866MYDYSON (US). I'm sure we'll be able to help.
Kind regards,
Jack
Jul 10, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC-35 Digital Slim Cordless Multi-Floor Vacuum - - Logo
138 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
