Question about Kenmore HE2 Plus Front Load Washer
1is there a plastic ball inside the Kenmore he2 plus front loader washer drain pump hose
I unhooked the drain pump hose and there was a plastic ball located inside the large end of the hose. I was wondering if this was part of the assembly or if it was a clog.
    Master:
  • 379 Answers
I would not be so quick to judge it as a clog. Check valves often take the shape of a ball. In transmission and carburetors they are steel. Given that the he2 drum is lower then the drain connection in the wall it makes perfect sense for a check valve in the drain hose. If you can not see a way for it to get in there and it appears large enough to stop water form flowing back into the machine I am betting it is a check valve. Look carefully at how it might fit on the machine side of the line, if I am right, it should be able to block the hole. When water is moved toward the house drain, there should be no way for it to block the water. There is also a very good chance it is a solid ball. Look at it very carefully before deciding to remove it.
1is there a plastic ball inside the Kenmore he2 pl - 25317864-sg5jzysg2a0ofyvvnaypgjnd-4-0.png
Posted on Dec 12, 2014
Testimonial: "Thanks Raymond, you were exactly right!! I had taken it out, but I called a technician to come out yesterday to make sure. He could have literally just read your answer to me, because he said exactly what you said....and with haste, he put the ball back in. :)"
  • Raymond Richards
    Raymond Richards Dec 12, 2014
    Thank you, glad I could help.
    Scholar:
  • 159 Answers
Simply put it's a clogged in the hose.
jsrock516
  • 5911 Answers
SOURCE: Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
Posted on May 28, 2008
  • 188 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
Posted on Oct 10, 2009
  • 6 Answers
SOURCE: My Kenmore HE2 Plus Front Load Washer won't drain?
remove front panel at bottom, get a bucket & clean pump out
Posted on Nov 10, 2009
  • 1382 Answers
SOURCE: HE2 Plus front load washer keeps showing F21 error
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
Posted on Apr 01, 2010
My kenmore HE2 wont drain.
Hi there I suggest that some machines have that white ball to stop water from syphoning out of the machine when on a wash cycle but your problem is either a blocked pump, (try and take the pump off as some debris will go past the filter and stop the impeller from turning hence no water being pumped out) or a kinked outlet hose which can easily happen when you push the machine back into it's place in the kitchen.
I'm not too conversant with your make of machine but in general all machines are basically the same.
If you can't hear the pump spinning then it may be something more like one of the circuit boards may have failed.
Mar 11, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2Plus White Front Loader. Drain pump seems weak, wet clothes, and f-21 flashing..???
Hello & Welcome to FixYa
F21 error code is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Kenmore HE2 Plus Front Load Washer
It is blinking F21 and wont work I have cleaned the drain hose and water is going through the hose there are no clogs
Some times this happens if you are not using he2 detergent. This is sepical detergent for front loaders.
May 02, 2010 | Kenmore HE2 Plus Front Load Washer
F-21 on screen
Apr 09, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore front loader does not go into the spin cyclr and water is left in the drum
Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 - water leaking from bottom - almost like a garden hose? any ideas
remove panel on bottom usually three screws will remove panel then u can look inside to find leak.. check the drain pump for leaks or debri inside pump by removing cap u willl see down there... hope this helps
Feb 06, 2010 | Kenmore HE2 Plus Front Load Washer
I have an HE2 Plus Front Loader. When it drains,
Sounds like there might be something in the pump that got past the button trap. You will have to remove the pump to check it.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore front load he2 plus wont drain.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Aug 05, 2009 | Kenmore HE2 Plus Front Load Washer
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
348 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
